Snow Equipment Owning/Operating Should I take the tooth Bar off my FEL to remove snow?
   / Should I take the tooth Bar off my FEL to remove snow? #1
CrestonNC
Creston, NC
Kubota L3800
Getting a new tractor this week, the bucket has as tooth bar. My driveway is gravel and gently slopping. And advice would be appreciated.
Thanks
   / Should I take the tooth Bar off my FEL to remove snow? #2
I certainly would. IF a layer of hard packed snow/ice, then I might have it on for a short while.
But it depends on what kind of a job you are happy with. :)
   / Should I take the tooth Bar off my FEL to remove snow? #3
Yes - unless you are in an area with certain melting after storms, in which case you could probably get by leaving an inch or two behind by tilting bucket to not dig in and let the rest melt. In sustained winter conditions you want to be able to scrape the packed snow-ice down with the edge of the bucket and that would be nearly impossible to do without driveway damage with teeth on.
   / Should I take the tooth Bar off my FEL to remove snow? #4
Let me make it a third vote to take it off.
   / Should I take the tooth Bar off my FEL to remove snow? #6
It looks unananimous. Take it off or you'll be digging up your gravel driveway.
   / Should I take the tooth Bar off my FEL to remove snow? #7
I'm getting a new FEL with tooth bar and was wondering the same thing...thanks too.
   / Should I take the tooth Bar off my FEL to remove snow? #8
TAKE IT OFF BABY!!!!
or.... if you can justify it, and get a good deal, buy a second bucket.
-Jer.
   / Should I take the tooth Bar off my FEL to remove snow? #9
Remove the tooth bar, it only takes a few minutes.
   / Should I take the tooth Bar off my FEL to remove snow? #10
Take it off!
It's starting to sound like a strip club in here. :eek:
Joe
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2017 Ford F150 (A55973)
2017 Ford F150...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
John Deere 5105M (A53317)
John Deere 5105M...
