Snow Equipment Owning/Operating Should I take the tooth Bar off my FEL to remove snow?
   / Should I take the tooth Bar off my FEL to remove snow? #11
Well hey, if you leave it on the huge gashes in the gravel you leave behind could be used for traction :thumbsup:
   / Should I take the tooth Bar off my FEL to remove snow? #12
dex3361 said:
Remove the tooth bar, it only takes a few minutes.
Is there any risk to the mounting holes while it's off??
-Jer.
   / Should I take the tooth Bar off my FEL to remove snow? #13
I don't think so unless very heavy use with lots of scraping of gravel. If you think you'd use it in that way you could presumably use same holes to mounts a removable wear bar-scraper edge.
   / Should I take the tooth Bar off my FEL to remove snow? #14
Leave it on and try it that way. If it does not work to your satisfaction then take it off.:thumbsup::thumbsup:
Might do a good job of getting rid of ice??:D
   / Should I take the tooth Bar off my FEL to remove snow? #15
Another vote for taking it off. I take mine off each year and put it back on in the spring.
   / Should I take the tooth Bar off my FEL to remove snow? #16
I have a gravel drive also and I take mine off the bucket. Merry Christmas everyone!
   / Should I take the tooth Bar off my FEL to remove snow? #17
I only put the tooth bar on if I want to dig dirt.
Don't need it otherwise. It sticks out and is too easy to hang up on things, like garage doors, etc.
Ralph
   / Should I take the tooth Bar off my FEL to remove snow? #18
-Jer.
Been using my bucket for moving snow for about ten years...no problems with the toothbar holes.
I do suggest you paint the bare metal with Rustoleam or similar though.
   / Should I take the tooth Bar off my FEL to remove snow? #19
In this part of the country, you can be moving snow one day and moving buckets of dirt the next. Think I'll leave my toothbar on and see.:confused2:
   / Should I take the tooth Bar off my FEL to remove snow? #20
Yes....
Chris
2011 FORD F-150XL SINGLE CAB TRUCK (A58375)
2011 FORD F-150XL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
