Snow Equipment Owning/Operating Should I take the tooth Bar off my FEL to remove snow?
   / Should I take the tooth Bar off my FEL to remove snow? #11
Well hey, if you leave it on the huge gashes in the gravel you leave behind could be used for traction :thumbsup:
   / Should I take the tooth Bar off my FEL to remove snow? #12
dex3361 said:
Remove the tooth bar, it only takes a few minutes.
Is there any risk to the mounting holes while it's off??
-Jer.
   / Should I take the tooth Bar off my FEL to remove snow? #13
I don't think so unless very heavy use with lots of scraping of gravel. If you think you'd use it in that way you could presumably use same holes to mounts a removable wear bar-scraper edge.
   / Should I take the tooth Bar off my FEL to remove snow? #14
Leave it on and try it that way. If it does not work to your satisfaction then take it off.:thumbsup::thumbsup:
Might do a good job of getting rid of ice??:D
   / Should I take the tooth Bar off my FEL to remove snow? #15
Another vote for taking it off. I take mine off each year and put it back on in the spring.
   / Should I take the tooth Bar off my FEL to remove snow? #16
I have a gravel drive also and I take mine off the bucket. Merry Christmas everyone!
   / Should I take the tooth Bar off my FEL to remove snow? #17
I only put the tooth bar on if I want to dig dirt.
Don't need it otherwise. It sticks out and is too easy to hang up on things, like garage doors, etc.
Ralph
   / Should I take the tooth Bar off my FEL to remove snow? #18
-Jer.
Been using my bucket for moving snow for about ten years...no problems with the toothbar holes.
I do suggest you paint the bare metal with Rustoleam or similar though.
   / Should I take the tooth Bar off my FEL to remove snow? #19
In this part of the country, you can be moving snow one day and moving buckets of dirt the next. Think I'll leave my toothbar on and see.:confused2:
   / Should I take the tooth Bar off my FEL to remove snow? #20
Yes....
Chris
Billy Goat Walk Behind Sod Cutter (A57149)
Billy Goat Walk...
2010 Chevrolet Silverado Pickup Truck, VIN # 1GCSKSE32AZ233697 (A57453)
2010 Chevrolet...
Sedan (A59231)
Sedan (A59231)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
UNUSED JCT 84" HYD ANGLE BLADE (A58376)
UNUSED JCT 84" HYD...
2007 Western Star 4900 Semi (A59814)
2007 Western Star...
