Questions about UTB-445
   / Questions about UTB-445 #11
I got the Operator Manual for mine from a company in US. The UTB 445 was sold in America as a Long 445 & also as an Allis Chalmers 5045 ( also as an Oliver). I got the manual for an Allis Chalmers 5045 which is OK for most stuff but doesn't cover the 4 wheel drive (Mine is an UTB 445DT).
Some good info on
Your Long 445 Parts Source!
Some good info on
M-m. Maybe this a little stupid question, but can you scan manual what you have, please? :(
   / Questions about UTB-445 #15
Thanks, but I have already this information. I need more details. By the way, we bought oil SAE 80W-85 API GL4 for transmission, it's okay for using?
NO it is not you will ruin the hyd pump it's to heavy.
Hm-m. So bad. Anyway. Please, can you tell me for example what oil is good for use? I mean exactly names (not category).
   / Questions about UTB-445 #17
Nope - don't have a scanner
   / Questions about UTB-445 #18
My Universal tractor Oil is 15w 40 & I used it for both engine & transmission/hydraulics, but Wales is a temperate climate (even though we had a frost of -18 deg Celsius last week:shocked: )
You may need say a 5w 40 for the engine in a Russian winter though, depends which part of Russia you are!
As someone said, 80w 85 is way too viscous for the transmission/hydraulics. You'll probably break a drive key for the hydraulic pump if you use that in a Russian winter.
   / Questions about UTB-445 #19
What oils do you have available to you?
Shell,Mobil, Texaco,
Thanks A LOT for information!
Shell and Mobil. :)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
