Questions about UTB-445
   / Questions about UTB-445 #11
I got the Operator Manual for mine from a company in US. The UTB 445 was sold in America as a Long 445 & also as an Allis Chalmers 5045 ( also as an Oliver). I got the manual for an Allis Chalmers 5045 which is OK for most stuff but doesn't cover the 4 wheel drive (Mine is an UTB 445DT).
Some good info on
Your Long 445 Parts Source!
Some good info on
M-m. Maybe this a little stupid question, but can you scan manual what you have, please? :(
   / Questions about UTB-445 #15
Thanks, but I have already this information. I need more details. By the way, we bought oil SAE 80W-85 API GL4 for transmission, it's okay for using?
NO it is not you will ruin the hyd pump it's to heavy.
Hm-m. So bad. Anyway. Please, can you tell me for example what oil is good for use? I mean exactly names (not category).
   / Questions about UTB-445 #17
Nope - don't have a scanner
   / Questions about UTB-445 #18
My Universal tractor Oil is 15w 40 & I used it for both engine & transmission/hydraulics, but Wales is a temperate climate (even though we had a frost of -18 deg Celsius last week:shocked: )
You may need say a 5w 40 for the engine in a Russian winter though, depends which part of Russia you are!
As someone said, 80w 85 is way too viscous for the transmission/hydraulics. You'll probably break a drive key for the hydraulic pump if you use that in a Russian winter.
   / Questions about UTB-445 #19
What oils do you have available to you?
Shell,Mobil, Texaco,
Thanks A LOT for information!
Shell and Mobil. :)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
24in pin on excavator tooth bucket (A56435)
24in pin on...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
