How do they do it?
/ How do they do it? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I spent the last few days as follows ... Thursday 9 hrs at 2500 rpm .. non stop cutting hay, Friday 7 hrs of non stop discing, Saturday 6 more hours of discing and today 7 hrs running the baler ... all this at 2500 rpm with very few idle down times ... Got me to thinking about the importance of oil, trans/hydraulic fliud.
Just how do these machines endure this and some of them for several thousand hrs ....???
/ How do they do it? #2
Quality lubricants changed as required, clean filters, clean radiators or other heat exchangers.
kj
/ How do they do it? #3
Very good point, and maybe, just maybe...............some of the people that don't want to change the oil, or want to put it off for a while.........will see this thread.
/ How do they do it? #4
Over engineered.:thumbsup:
/ How do they do it? #5
Right equipment for the task also helps.
Good PMing leads to little down time.
/ How do they do it? #6
Depends on the situation...
If I got a crew (that's anything more than just me), I'll usually drop, cut to length and split on-site, into the pickup with the loader, then haul out and stack from the pickup.
If the access isn't good or it's just me, I'll drop and skid to a landing area where I'll split right into the loader bucket and stack from there. A lot of times I'll have other wood waiting to be split at the landing area that I've picked up elsewhere, from tree trimming or storm damage, etc.
As someone else said, no matter how you do it, it's still a lot of work. But what's wrong with that? What else you got to do? Sox are done, so the baseball season is over... ;)
/ How do they do it? #7
Oops - wrong thread. You may want to move this to the firewood tread BeeferMan. They were side-to-side so you must have clicked on the wrong one.
/ How do they do it? #8
Right you are, thanks! Chalk up another user error due to pre-coffee posting... :D
/ How do they do it? #9
Detuned may be a better term. The same engine block may be used in another application turning 2x RPM and making 4x the HP. Moving at 8 MPH is a lot less demanding than 80 MPH on some parts. Tractor gearing when pulling heavy loads is under a lot of stress but at low speeds.
I do not go by the manual for scheduled service ... I believe oil, filters are the life support. If I have used the tractor(s) hard and steady. I just drop the oil and filter ... Its been 68 hours since the last change and tommorow there is a chance of rain ... Cheap maintaince.
/ How do they do it? #11
How do they do it?? Simple. Diesel engines turn much slower rpm's than gas engines. So they dont wear as fast which is why Semi trucks can go millions of miles. Gearing is key also. My 60 hp diesel tractor can pull more than my 300 hp suv. Tractor engines arent always working as hard as you think they are. Which is why there are so many other wearable parts on a tractor. It takes me a good hour to grease every grease fitting on my tractor. Good maintenance is important
/ How do they do it? #12
Diesel engine life as opposed to gas engine life goes much further than the difference in engine speed.
To start with diesel fuel is an oil and as it burns in the diesel process it does not produce the same carbon as a gas engine. The carbon in a gas engine is abrasive, adding to engine wear.
Also, in carbureted gas engines, cold start requires use of a choke which introduces raw gas into the cylinder which washes oil off the cylinder walls contributing to rapid cylinder wear. This is the main reason for so much longer engine life in EFI gas engines.
Additionally due to compression ratios typically twice as high as gas engines, engine components must be built much stronger. This rigidity of components contributes to less engine wear.
All this said, I still agree with the oil change nature of this thread. I am an oil change fanatic. I always pull the drain plug when the engine is completely warmed up and let it drain overnight. Those last few drops are the gunkiest of what comes out. I have achieved very good engine life from my engines which have always had such frequent changes using my extreme method.
/ How do they do it? #13
That is key, even to gas. My old Farmall-A redlined at about 1600rpm. Those motors lasted forever. Same for a lot of those old gas engines in JD, AC ect.
Diesel though, use a lot less fuel, with less cubic inches. My old Kubota was 19hp, 60CI, my old Farmall was 22hp, 113CI.
/ How do they do it? #14
Well, Mr. Rogers would say, "It's a wonderful day in the neighborhood." The engines and transmissions we have in our equipment today are truly marvels of function and reliability. Diesels have been reliable for a long time as well as low rpm gasoline engines. When you think about it, 2500 rpm is very low compared to high rpm conventional engines and turbines. Superior materials, lubrication, and temperature control of critical bearing surfaces is surely responsible for long life. OTR trucks, ships, and airplanes are fascinating for their reliability. Perhaps the modern tractors and farm equipment should be included in that list. I can remember when cars were traded before 50k miles, but today's cars can routinely go 200k miles if maintained properly. The good ol' days are right now.:thumbsup:
Anyway ya look at it ... its pretty darn impressive. I recall seeing a JD at auction with 8500 hours and it still purred like a kitty in a milk parlor... thinking of that wonder what the most recorded hours on a tractor are?
/ How do they do it? #17
Those old Romanian tractors I hear are the most durable tractors ever built. The engine blocks on them are really thick and the cranks are huge. Designed to run forvever.
/ How do they do it? #18
A constant rpm is also helpful to a long engine life.
/ How do they do it? #19
I used to be in the navy and one boat I sailed on was diesel electric (3 diesels). We went to the arctic one summer and 2 motors were always running. We were there for almost 2 months. I understand your amazement
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
