Building a Shop
/ Building a Shop #141
you need to write a book after this. The puter-upper is a great idea. I've watched this thread since you started and have learned a lot from it. I'll almost be sorry when you get the barn done. Which looks like that will be very soon.
Wedge
/ Building a Shop #142
Nice job on figuring out how to put those panels on by yourself. I like the guide/restraint at the end of your lifting tool to keep a wayward panel in place should the wind kick up.
/ Building a Shop
Roof's on...mostly
The steel sheets are all up on the roof and screwed down completely now. I put about 1/2 of them up on Saturday, almost finished yesterday, had to put the last piece up tonight.
The putter-upper worked great. I ended up abandoning the vice grip on a rope. Instead, I would position the 'upper just off to the side of the spot I intended the sheet to go into. Then from a ladder at the eave, I'd pull/push/slide the panel off of the 'upper and onto the roof. Once on, I could slide it over to get the overlap rib lined up. I would line up the bottom end, and screw the sheet to the eave fascia board. Then I'd climp up at the peak from inside the shed and screw down the top to a couple purlins. Once the panel was secure, I'd climb out onto the roof, staying on the last fully screwed sheet, and work my way back to the bottom, fastening the new sheet the rest of the way down, then climb down off of the eave ladder.
The Cleary kit came with nails for the roof steel, but I decided on screws mostly to save my arm/wrist from pounding that many nails. I picked up 1.5" pole barn screws from Menards in their "Emerald Green" color. Those screws looked nearly the same color as the Fabral screws that came for the Cleary "Evergreen" wainscot. Turns out, the Menards screws and the Fabral screws are made by the same company. Not sure they'd 100% match on a wall where you'll stare at them all day, but for a roof, they're darn close.
/ Building a Shop
Last pics I took before it got dark last night.
/ Building a Shop
Latest status:
Just an update on the shop project. The roof's complete, including the ridgecaps/vents. Most of the trim is up, just missing a couple pieces on the back end of the roof (corner pieces on the roof edge). Have a few spots that I need to go back over and finish screwing down the wall steel, but it's all on pretty solid. The electricians put in the panel and an outlet a few days ago, no more hundreds of feet of extension cords! :) Found out that the overhead door will be installed tomorrow sometime, which will pretty much finish off this year's part of the build.
/ Building a Shop #146
Latest status:
Now you can get that lot graded and seeded. :)
/ Building a Shop
Cleaning up the grade and seeding is yet another project that won't get done this year... Around the house, the grade is pretty good. Still some work I want to do around the shop to improve drainage and to take down a little bit of a hump and use that dirt somewhere useful.
Dad's got an old disc harrow I'm going to haul back one of these days. He's pretty sure my tractor will pull it ok, especially for light grass-seeding prep work. We shall see.
/ Building a Shop #148
Huskerplowboy,
Just want to thank you for the wealth of information you have given us and wanted to tell you that you did one heck of a job. I am probably going to do much of the same type project starting this spring and I feel much more comfortable now that I watched you build yours. I have visited the website that you bought your package from and I did not find the 30x40that you built, was yours a special order? Also if it is not asking too much.... could you give us a ball park cost of your package? Sure would appreciate it!!
Once a gain - Fine Job!!!
/ Building a Shop #149
I to want to thank you for the on going pictures of your project! Keep them coming when you start the interior work! Learned alot from your posts.
/ Building a Shop
Huskerplowboy,
Here's the link to Cleary's DIY "Suburban" buildings: Cleary Building Corp. - Commercial Buildings
Mine was somewhat custom since I went with the taller sidewalls. Cleary would call mine 13'4" compared to the 11'4" "stock" kit they have online. Otherwise, I think the rest was pretty much the same. I think they can do a material only deal on just about any building. The salesman mentioned that the stock buildings might be a bit cheaper since they're a canned design and material list, no need for any designers to do anything if you order one, just pull the material and ship it. On the other hand, anything custom means that someone has to spend at least some ammont of time modifying material lists, drawings, check loads, etc...
My 30x40x13'4 kit was around $11k or so.
/ Building a Shop
Starting to actually become a shop...
Long time since the last posts. Back in early August, I was finally able to get a crew in to pour the floor in my new shop. Prior to that, I had a lot of lot grading to do back in the sping, lawn seeding, and in July I trenched in some drainage tile under the shop floor pad including a stub for a floor drain. Turned out well, now working on getting the lights and outlets wired.
/ Building a Shop #153
Is that concrete on the lower panel? Unless you washed it off right away I have the feeling that it is there to stay!!! Nice watchdog too.
/ Building a Shop #154
Great to see you back! Please keep the pictures coming of the interior work. Followed your project from the start.
/ Building a Shop #155
Hey Husker! I was just wondering the other day what happen to you and your building out in the "corn patch". I figured with the house build and all at once you had to put the shop on the back burner. Good to see an update.:thumbsup:
/ Building a Shop #156
I have really enjoyed watching your shop being built. You have given me some great ideas. Thanks for taking the time to document and post pictures. It looks great.
/ Building a Shop #157
Looking good! Love the shepherd.....
/ Building a Shop
Nice watchdog too.
Not sure she's much of a watchdog, but she's pretty good at laying down and looking exhausted after a hard day of watching me work!
/ Building a Shop
Yeah, I'm not going to lie, the shop is definitely not the #1 priority around here. That's not my choice, but the "finance committee" seems to think the shop is less important... Seems like there's always some honey-do project I have to check off before I get to work on the shop each weekend...
I do have the wiring partially done. I have all of the interior lights up, wired, and working. I put them on 2 switches. The first one has two 8' fluorescent strips and 2 regular light bulbs on it and covers the front half of the shop. The light bulb fixtures are on either side of the overhead door, so they aren't blocked by it when it's openned up. The second switch turns on four more 8' strips for the back half of the shop. With all 6 on (each strip takes four 4', T8 tubes at 32W each), they really light up the work area. I still need to hang and wire an outdoor floodlight to shine outside of the oH door, but that's lower priority.
I also managed to hang up all outlet boxes and have the North wall's outlets hooked up and live. I also have the wire pulled to the West (back) wall outlets, but not yet hooked up. Still need to run wire to the South wall bank of outlets and one separate outlet over in the SW corner where I'll set up a computer or more sensitive things. With the exception of the one single outlet for the computer, which is a 15 amp, all outlets are 20 amp outlets on 20 amp breakers. I'm prone to overkill, so all of the 20 amp outlet circuits are using 10 gauge wire even though 12 gauge would be acceptable...
All tallied up, I'll have 6 outlets on the North wall, 4 on the West, and another 5 on the South wall. Should be enough...
2007 JLG 3246ES ELECTRIC SCISSOR LIFT (A62129)
2007 JLG 3246ES...
Landhonor LHR-WCF330A 330lbs Wagon Foldable Cart (A60353)
Landhonor...
2025 Wolverine TP2-13-08D Hydraulic Tree Puller Skid Steer Attachment (A60353)
2025 Wolverine...
2015 John Deere 350G Hydraulic Excavator (A60352)
2015 John Deere...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A62130)
1987 FORD F-350...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
