My Barn..... Finally !!!
/ My Barn..... Finally !!! #21
Ok, can't help kibitzing. A couple of things to consider:
1. Penetration points for power, drains (a sink is a god send), outdoor power, water faucet. I made one entry point in the floor (just a wood frame to block the concrete and backfilled with gravel when I got the water run). I wished I had done that around the pre-placed electrical conduit. Underground kept the metal from being penetrated.
2. Presuming this will be metal sided, there are preformed foam 'rubber' pieces for the ends of the panels (and the wll to roof joints). Make it a LOT tighter.
3. Cut floor crack joints. Same thing they do to concrete freeways. Is amazing in how much easier it is to use your shop floor when moving or setting up equipment. Or a creeper. You can pour the flat work later, allowing you to finish the penetration points and to set aside a bit more money.
4. Don't know what kind of doors you are using. Mine has side sliders (conventional barn doors). Other than the issue that the full height has to open, they are simple, and they are cheaper (a place money can be diverted from). No auto door openers though. And no overhead space issues (space the door opens to). I also agree on the door opening -- 9' is too small.
5. The easy directions to add space are to either just extend the roof out (in your case only the side without the doors) or to extend off of the end. Just a thought if you have any pretensions for the future.
6. For you wood shop, if you can think this in advance, it can be a real plus to have a small door that allows long timbers to stick out of your shop along the path your chop/radial saw and bench would be. Just a 2' x 2' or less door with the bottom at the same level as the work surface (even if it does not extend to the wall/opening). Amplifies your space with little impact to your work area by being able to leave the part not being used outside, but accessible from the inside.
7. No one will ever build the perfect shop -- just get closer to the mythical Nirvana. There's nothing like a Man's new shop -- Manland! Congrats!
/ My Barn..... Finally !!! #22
I just finished my barn/shop and have 1 12ft door at one end and 1 10ft door at the other end sure wish I had made both 12ft. You must be very streight to pull or back a trailer in the 10ft door. My doors are swing doors I made using 2x2 tubing with 5 regular 4 1/2 in hinges on the doors the doors but the drop out for the tin which makes a good fit. 2 doors in each opening 10 ft tall. When I learn how to send pictures I will send some. These doors are real cheep and easy to make.
Kicking back just inside the open doors from days heat or when mother nature decides valley needs showering,ahhhh yes home away from home. ;)
Good Afternoon Guys,
Thanks for all the helpfull ideas ! :)
The trusses have been ordered, sorry on the delay, but just last week week we had another 6" of oh yes , SNOW ! :D
The dozer will hopefully be there next weekend, like I said hopefully ! :eek:
I will probablly have a wood stove in the woodshop along with a forced hot air ceiling mount heater...
Hopefully will have some pics soon....
In the mean time, Im driving by other barn/shops saying, oh yea mine will be bigger than that or some such nonsense... ;)
Alan, BTW very nice ! :)
Alan did you say something about a man cave ??? ;)
I have a beer refrigerator ready to go, although we havent moved a blade of grass yet...
I can certainly picture it loaded with Coors Light and of course a bottle of Fire Ball for medicinal purposes only ! :licking:
BBTW, Beam I cant afford another Hearthstone anytime soon !;)
/ My Barn..... Finally !!! #24
Sounds like you have put a great deal of thought into what you want. Everyone has great ideas, but we all have to know where to draw the line. Mine is close to being done and I guess there are always things I might have done different. That is why you never build the final garage. There may always be another down the road. Good Luck and I look forward to seeing your shop become an actual building. I tried to save money, but in the end you can save on big items. The little items are what really cost in the end. I spent $300-400 just on sealant for the concrete.
/ My Barn..... Finally !!! #25
Yea, but your barn is SWEEEEEEEEEEET!:thumbsup:
Good Afternoon hc,
Well I got the invoice in the mail today from MacLeod's Lumber, they are out of Whtehall, Ny.
The total bill for all the lumber, trusses, and associated material came out to $16,213.39.
I am prepaying for all the lumber so as not to incurr any further price increases over the next couple of months.
Unfortunately the trusses are on there way allready, and we will only be doing the bulldozer work this weekend..... :(
Hopefully the slab will be done by next weekend weather permitting, so those trusses are not laying around too long...
Im hopefull to have some dozer pics by this sunday or monday, and will post as soon as I can ! :)
So to date I have $21, 213 payed out and not a blade of grass moved yet:confused2:
I will keep you all updated !
BTW if I had Robs money, thats my buddy 3RRL, the barn would be much bigger and done allready ! :p
/ My Barn..... Finally !!! #27
Holy moley, I may have to make a road trip some upcoming weekend !
Late to the party, but congratulations on the barn build. :licking:
/ My Barn..... Finally !!! #28
Scotty, congratulations on getting your barn started. Have you considered adding some duct work under the slab for a dust collection system in the wood shop? They sure are nice if you do much wood working. Not to expensive to do now and almost impossible to do later. You might also add a small slab outside the building that could be closed in to hold a compressor and dust collector. Eliminating those items from the interior makes for a much quieter man cave as you contemplate life.
MarkV
/ My Barn..... Finally !!! #29
I can't wait to see the pics of the job in progress. Congrat's!
Good Evenin Guys,
Scott your allways welcome, beer and food provided !
Mark and Jimmy, thanks !
The tough dozer work is done, here are a couple of shots, sorry not so great ! :(
I will have two large truck loads of gravel brought in for the base and two loads of crushed shale for the bank that sticks out and for the ramp into the garage section...
We did make a small change, the drive through bay will be the second door over and thats where my floor drain will be...
I will have some dozer shots tommorrow... :)
The base will be vibratory compacted, hopefully things wont move too much after that ! :)
Also the bottom sill plate that contavts the concrete will be PT and J bolted to the concrete...
Gotta go and take Mom out will be back later...;)
/ My Barn..... Finally !!! #31
Nice building pad Scotty. Is that dozed dirt settled/compacted enough to pour a slab on? I know you will compact the stone on top, but the dirt below needs to be solid too. Are you putting sill seal between the PT sill and slab?
Nice location for your barn. Did you order up this great weather for building? :D
Dave.
/ My Barn..... Finally !!! #32
Dave.
We sent it over so that you guys could enjoy what we've been seeing for the last couple of weeks.:D Enoy!:laughing: I know that I'm sure liking the sun which has finally replaced it!:thumbsup:
/ My Barn..... Finally !!! #33
Cyril,
We have had windy, chilly, cloudy weather lately. It's 36* now, feels like winter is coming instead of leaving. :) At least it didn't rain all day like yesterday. Send that sunshine over.
Dave.
/ My Barn..... Finally !!! #34
Cyril,
Dave.
You'll have to wait a few more days...we're still getting it properly broke in for you.:laughing:
/ My Barn..... Finally !!! #35
Cyril,
Dave.
I don't know if Scott was spared but a little further north we had an inch of snow today. If not for the warm ground it probably would have been more since it snowed all day long and is still snowing as I type.
dcyrilc, thanks for thinking of us. Next time could you please just send a post card of the bad weather.
Dave.
Good Evenin Dave,
Yep the sill seal is supposed to be used, I will check with my contractor, since it gets a tad windy up there at times ! ;)
Good Evenin Al,
We got some snow flakes but nothin that amounted to anything... But Sunday mornin the deck on my porch was mostly ice ! :D
As promised a couple of dozer shots...
The dozer was driven over all of that dirt that was moved but it was only a JD 450 so not a great amount of weight,,,
/ My Barn..... Finally !!! #37
Evening Scotty,
Not sure if the dozer's weight is enough. Maybe someone has a better idea on it. You could run your vibratory plate compactor on the new pad soil before putting stone down, and compare what happens to running it on undisturbed dirt as a sort of test. You don't want to have settlement under your slab. Might depend on the soil type too, like if it is clay.
Dave.
/ My Barn..... Finally !!! #38
I'm about to start a garage also using an Alaska slab. I'm going to put down a layer of washed stone down first to promote drainage.
http://www.todaysplans.com/drawing-floating-slab2.pdf
My plan is to disturb as little of the ground as possible then put the stone on top of it. I have to dig down where it looks like you had to build up.
/ My Barn..... Finally !!! #39
Just got the sun broke in properly for you. Nice and warm, just the way you like it. You guys should get it in a few days.:thumbsup:
/ My Barn..... Finally !!! #40
Scotty,
I did my own foundation for my barn.
I used 3 to 4" lifts of DG (decomposed granite) to build the foundation. After every lift, I wetted it down and drove the Kama tractor over every square inch. I did this until I got the desired height and width for the building pad. Then I used my boxblade to cut and level the pad. It came out so compacted that my contractor was laughing at me when I asked him if it was good enough. He had to use a hammer to pound in his layout feathers. So if that dozer did something similar, I'd think it should be plenty good.
Keep the photos coming.
Rogator RG1300C (A63688)
Rogator RG1300C...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A61574)
2010 Mercury 15HP...
