2210 battery replacement?
/ 2210 battery replacement? #1
megotatractor
New Richland, Minnesota
JD 2210
I saw a post on here about a replacement battery for a 2210, one that doesn't leak and corrode the SHI! out of everything? Optima or something? Can someone post a link? My original battery is still good after 6 years but when the machine sits for any length of time corrosion abounds. While doing the 500 hour service this ended up including repainting the area under the battery and replacing a hold down J bolt.
Thanks.
/ 2210 battery replacement? #2
Thanks.
Yes, Optima...Do a search.
GULP! yes I suppose the extra cost is worth it, better than letting acid eat the front off the machine.
Just realizing that this month is my 2210's 6th birthday! Maybe I'll get a cake! <:O)
/ 2210 battery replacement? #4
Just give it a good battery for a present!:D
/ 2210 battery replacement? #5
Just added an optima to my 4210 last fall. Best thing I have done. I had a post with part numbers.... I will dig it up..
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
Colombo Twin Master (A64126)
Colombo Twin...
