2210 battery replacement?
/ 2210 battery replacement? #1
megotatractor
New Richland, Minnesota
JD 2210
I saw a post on here about a replacement battery for a 2210, one that doesn't leak and corrode the SHI! out of everything? Optima or something? Can someone post a link? My original battery is still good after 6 years but when the machine sits for any length of time corrosion abounds. While doing the 500 hour service this ended up including repainting the area under the battery and replacing a hold down J bolt.
Thanks.
/ 2210 battery replacement? #2
Thanks.
Yes, Optima...Do a search.
GULP! yes I suppose the extra cost is worth it, better than letting acid eat the front off the machine.
Just realizing that this month is my 2210's 6th birthday! Maybe I'll get a cake! <:O)
/ 2210 battery replacement? #4
Just give it a good battery for a present!:D
/ 2210 battery replacement? #5
Just added an optima to my 4210 last fall. Best thing I have done. I had a post with part numbers.... I will dig it up..
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
