dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,711
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
You can access the PTO brake thru the rear cover, and you may be
able to see the problem from there. You take off the PTO gears
and the rear bulkhead. If you have to remove the clutch, that
requires taking the 3-pt cyl housing off. When you remove the rear
cover, you may find your broken parts in the bottom of the gearcase.
In this photo, you can see me removing the brake basket from the
rear (snap ring pliers reqd). At the top you can see some of the
fingers or pawls that may be your problem. They can hang up or
brake off.
BEENTHERE's manual photos should help, too.
brake off.
