4300 PTO won't disengage.
   / 4300 PTO won't disengage. #11
You can access the PTO brake thru the rear cover, and you may be
able to see the problem from there. You take off the PTO gears
and the rear bulkhead. If you have to remove the clutch, that
requires taking the 3-pt cyl housing off. When you remove the rear
cover, you may find your broken parts in the bottom of the gearcase.
In this photo, you can see me removing the brake basket from the
rear (snap ring pliers reqd). At the top you can see some of the
fingers or pawls that may be your problem. They can hang up or
brake off.
BEENTHERE's manual photos should help, too.
   / 4300 PTO won't disengage. #12
Here is the photo I mentioned.
OK, thanks for the manual photos beenthere. very helpful. I was going to pull the rock shaft housing off the top, as you did in your rebuild dfkrug, but I may just remove it from the back per the manual, that looks pretty simple. I can tell the fork is hitting something solid inside, I know that much. I'll get her apart and see what i find.
ya I got a manual but it doesn't go into much detail about wether the pto disengages with the clutch or not. Seemed like it SHOULD work that way but guess its just the 9n, massey 245 and JD 4020 in me... call me old school.
   / 4300 PTO won't disengage. #15
Bill, the PTO control lever is designed to be engaged or braked....there
is no neutral in between. The springs that hold the shifter in either
position are quite strong. If the lever can hold the shifter between
engaged and braked, there is already something wrong.
This is an unusual PTO mechanism for any tractor, and there were lots
of problems with it. Enough problems that JD dumped it on the 4x10
models. Mine is fixed, but it still does not always engage smoothly. It
works better if the the oil is warmed up and flowing (splashing).
To start and use your tractor in the interim, you need to put a jumper
across the PTO safety switch on the left upper side of the gearcase. You
can see the switch (with the connector off) in this photo on the left edge
of the picture.
   / 4300 PTO won't disengage. #16
Bill, the PTO control lever is designed to be engaged or braked....there is no neutral in between. The springs that hold the shifter in either position are quite strong. If the lever can hold the shifter between
my 4300 does have a neutral position...which i believe is PTO OFF, but not braked. it free spins, but w/ no real power. it is in between ENGAGED and OFF BRAKED.
   / 4300 PTO won't disengage. #17
I agree with you defed. My 4300 clearly has a neutral position, but am thinking either later models may have that either/or lever. The lever has a distinct position for engage, and disengage (braked) with a neutral spot resting in between. It snaps into engage as well as braked with a distinct feel to it. My 4300 is an older model ('99)
Might it have come along with the ehydro?
   / 4300 PTO won't disengage. #18
Mine is a 2000 model with HST. The 4x10s (eHydro and Gear) have gone
to a PTO system that uses electric control.
I went back to the owner's manual when you guys reported having a PTO
lever neutral positon. There is no reference to a Neutral anywhere for
either Gear or HST tractors. All mention of engagement/disengagement
of the rear PTO told of an Off position and an On position only. In one
place, the OM talked of pushing in the foot clutch on a Gear model before
moving the PTO lever to On. Then there is this photo in the manual, which
shows the PTO lever in a middle position, which is marked with some
unreadable graphic. My tractor's plastics are all new, so I don't have this
graphic. Does anyone else?
When I reassembled my PTO clutch/brake system, but before I put the
3-pt cylinder cover back on, I operated the PTO control lever repeatedly
to make sure everything worked. There was no middle (neutral) position.
Perhaps there are some variants that DO have a neutral, but I suspect that
some systems are just not working correctly.
One final note: I was working on the 4300 yesterday (subframe fab) and
I operated the PTO lever. It has always been balky, esp when going to
the OFF position. It engaged OK, but it did not want to go OFF for a while
as the tractor warmed up. I did not want to force the lever and break it.
Eventually, I got it to disengage.
   / 4300 PTO won't disengage. #19
i have a 2001 4300. in my manual, it does not say anything about a neutral. it does have the 3 graphics as your picture shows. one is obviously engaged, the other off, the middle one is a picture of a tractor w/ an arrow in the middle. i have to go check for sure, i can't remember exactly what it is. i can get a pic this wkend that shows it better.
i did ask about this on this forum and it was said that it is a neutral so you can spin it by hand w/ the engine off to align implements easier. granted, beenthere said it in both threads. :laughing:
http://www.tractorbynet.com/forums/...ng/166556-power-take-off-lever-positions.html
   / 4300 PTO won't disengage. #20
I found the graphic. It is as you said: a tractor pictograph. The arrow
is pointing at the rear of the tractor. Just a complicated way to say, "rear
PTO".
The PTO brake basket on my 4300 is designed to freely rotate maybe 120
degrees while the PTO is Off (braked) so you can turn the PTO shaft by
hand to get the driveshaft to go on. It is not a neutral.
CONCRETE POWER TROWEL (A55787)
CONCRETE POWER...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A54607)
2004 TRAVIS 48'...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2015V Chevrolet Equinox SUV (A55758)
2015V Chevrolet...
UNUSED LANDHONOR FW-13-15000G HYD CABLE WINCH (A54757)
UNUSED LANDHONOR...
