Another use for Fluid Film
/ Another use for Fluid Film #21
I used silicone spray on my snowblower in years past, works like a charm for sticky snow. The only problem is when you go to touch up the paint in the spring, the paint won't have anything to do with the sprayed surfaces.
Chilly
/ Another use for Fluid Film #22
I thought spraying fluid whether Fluid Film or WD on lock was not good as it would cause dirt/dust to stick to them and gum up the works!
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Set 4 - 10-16.5 tires on wheels for bobcat (A61572)
Set 4 - 10-16.5...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
207275 (A52708)
207275 (A52708)
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2022 EZ-GO ELITE...
