Another use for Fluid Film
/ Another use for Fluid Film #1
ccsial
NorthWest Illinois
(Kuboto L3400) (Ford 1900 4WD w/FEL) (Deere X748SE) All bought new
I went out to clear off 8 inches of wet heavy snow, The stuff that always plugs my blower. This time I had a thought and sprayed the chute and impeller down with fluid film. Two hours of blowing and no plugged chute, not even any sticking to it. It really worked.
/ Another use for Fluid Film #2
Nice. Maybe I'll try it on the underside of my mower decks next year. :) Just got my shipment last week. Sprayed it on the moving parts of my front blade. Nothing to report yet but everyone who uses it swears by it.
/ Another use for Fluid Film #3
Never heard of it! Use to use Garry's "It" silicone spray! Was suppose to coat my mower bottom and blower chute with this stuff:
EZ-Slide Alkyd Based Graphite Lubricating Paint
But of course never got around to it and now we're facing this winter blast!!! :( ~Scotty
/ Another use for Fluid Film #4
a year ago they sent me a free sample to try. i love the stuff. just ordered a couple more cans. its fantastic stuff. doesn't wear off easily. like wd40 but sticks like grease.
/ Another use for Fluid Film #5
Saw some of the posts here about Fluid Film and bought a spray can to try on my hydralic cylinders to reduce possible rust. I had been using WD 40. Based on the praise of the stuff here on TBN I thought I had better try it. I sprayed it on my backhoe cylinders since it is currently off the tractor and I want to reduce chance of rust. I went back to the backhoe after a couple of weeks and the cylinders were pretty covered with flying bugs, gnat like. They must have liked the stuff.
/ Another use for Fluid Film #6
ha!!! at first i hated the smell of it. its so funky, but now i really like it. smells kinda good. i did the same thing with my hoe. it has been on there for a few months now and there is a really nice coating still on it. it doesn't evaporate away. leaves a coating kinda like spray on lithium grease.
/ Another use for Fluid Film #7
Will this stuff harm the seals in the front of the cylinders?
/ Another use for Fluid Film #9
It does not contain solvents which is a good thing when it comes to seals. The solvents in allot of products can dry them out and actually cause damage.
Fluid Film contains no solvents. That statement alone means a number of things:
1) No evaporation. No evaporation means more useable product, which in turn means a much better value for your money. Most competitive products contain as much as 70% solvent, meaning most of what you spray evaporates and contaminates the atmosphere.
2) Non-tacky application. With solvent-based materials, the end product ends up being a gummy, sticky mess. Fluid Film will NEVER get tacky, retaining a super-slick consistency that provides excellent lubrication for moving parts on all metals.
3) Eco-Friendly. No solvents means no ozone depleting chemicals contaminating the atmosphere. It is classified as non-toxic and non-hazardous and is safe to be used inside the home, as well as out in the field.
Fluid Film is manufactured using an all-natural lanolin base. Lanolin is of animal origins, extracted from the wool of sheep, which use it as a waterproofing wax to aid in shedding water from their coats. It has been used for centuries for its medicinal and rust-preventive properties.
From one of our site sponsors Kellsport Prouducts proudly presents Eureka Fluid Film
/ Another use for Fluid Film #10
[Quote:]
Originally Posted by roadhawk
This was my first response too when I read it but laying in bed last night for some reason it popped back into my mind. Soooo...... how about it from the main man? Will it mess with the seals over time (so slick that they don't seal as well maybe?), and the bit that gets through the seals, will it mess with the hyd-oil?
I had to get a tech opinion on this. Here it is.
A) Will not effect the seals. Fluid Film itself is probably no slicker than the oil behind the seal. It's just not petroleum based. Fluid Film is not known to have any significant effect on rubber.
B) If some were to get beyond the seal, it would certainly be an insignificant amount. And even if a more substantial amount were to mix with the oil, there is no known negative issues.
__________________
Eureka Fluid Film Warehouse Distributor
I forgot to add bob's reply from the fluid film thread in the oils and lubes section. http://www.tractorbynet.com/forums/oil-fuel-lubricants/156161-eureka-fluid-film-7.html#post1803012
/ Another use for Fluid Film #11
I'd be careful of using WD40.
On my pickup cap I used it to clean and lube the pneumatic spring loaded piston things that keep the rear door up.
It seemed that the seals used on the lifters were allergic to something in the WD40 and within days the rear door stopped working.
Must depend on the type of seals used, ie rubber, vitron butyl etc.
/ Another use for Fluid Film #12
WD40 is a combination of solvents and petroleum products. The solvents will attack natural rubber causing it to dry out and the petroleum will cause the rubber to swell.
/ Another use for Fluid Film #13
fluid film is supposed to be a natural product, lanolin based i believe.
/ Another use for Fluid Film #14
Good cautions and warnings about WD-40. I have used it probably where I should not have. For about a year sprayed on my cylinders. Recently started with the Fluid Film based on what I read that it last/sticks longer. The Fluid Film site indicates there can be some swelling of natural rubber but not others. So far so good!
/ Another use for Fluid Film #15
I want to first state that, bar none, Fluid Film is the best spray lubricant that prevents rust available. It does have an odd smell to it and an even worse taste. Now before you go getting strange ideas, it DOES say that it's completely safe! Still, I would advise against spraying anything full blast through the straw with your face close to the surface. You'll get the splatter!
/ Another use for Fluid Film #16
Has anyone ever tried it with padlocks? I have a problem here, when it gets cold, with frost settling in the locks and freezing. Makes for a real pain opening the lock in the morning when the tumblers are frozen. Was wondering if it might help keep moisture out.
/ Another use for Fluid Film #17
I have sprayed WD40 into all my padlocks and car doors for the last 20 years and never had a frozen lock yet.
Just a little pssht* will do it. *tap of the nozzle!
Works for me!
But don't wipe/spray on tail gate lift springs as I had bad luck there, (ate the seals on my PU cap lift gate.)
/ Another use for Fluid Film #18
Fluid Film is the greatest. I posted this once before but I just bought new cowboy boots (not fancy, plain for working) and the salesman told me the best treatment for waterproofing etc was ......you guessed it....Fluid Film.
Now I wonder how the stuff is on ice cream...
/ Another use for Fluid Film #19
Works for me!
I would use fluid film in the locks since it will not freeze or wear off easily.
I had to replace the thermostat on my Grand Caravan and WD40 made for a great gasket remover. It helped cut through the adhesive they use on the gaskets. Thats one advantage of using a product with a high VOC content.
/ Another use for Fluid Film #20
I have used it in locks for the last 2 winters, and it seems to work better than the graphite based Lock-Ease. One thing I did notice is that it gets kind of stiff when it is real cold. Still beats heating up the key and lock with a lighter.
