Truck Tires for a Trailer
/ Truck Tires for a Trailer #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I'm sure this has been discussed, but I like to revisit it. What are the implications of using light truck tires for a trailer vs. using purpose made trailer tires?
I had my old beater trailer out this weekend, and while I had it out I did some work on it. I tightened a bunch of the deck bolts, welded D-rings on the sides for tie-downs, welded a bracket and attached a hand winch, and welded the wheel wells on better. Now that I've done this much, the four mismatched weather checked truck tires on it and rusty rims are begging to be replaced and repaired. The plan is to get the tires un-mounted from the rims so that I can sand-blast and paint the rims. Then I'll replace the tires. I have a friend who can get me any kind of used truck tire I want for only $10 each. He may have some used purpose made trailer tires, but no promises. What would be the advantage to holding out for the trailer tires?
/ Truck Tires for a Trailer #2
If you go with truck tires they don't hold up as well when you turn with 2-3 axle trailers but I have been using 235/85/16 lt 10ply load range E tires on my trailers for yrs as that is the same tire most of my trucks have used over the yrs.
/ Truck Tires for a Trailer #4
Guys are right but my experience with trailer tires are there are no good ones anymore. 3-4 years ago Goodyear Marathons were the cream of the crop but not anymore. I got less than 3 years and 5,000 miles out of my last set. The trailer lives in a pole barn but still dry rotted all to crap.
Truck tires at that price is a good way to go. I really wanted to put raised white letter truck tires on my boat trailer but could not find them in the proper size. I have been running Greenball Tow Masters made in China for the last 7 years on dozens of trailers with no issues.
I would go for the truck tires. Have him get you a couple spares and wheels if possible.
Chris
Here are some pics of the trailer. You can see that it's not something that has to be all perfect.
I've included a picture of the whole trailer and a picture of the mismatched wheels and tires. I also threw in a picture of one of the D-rings and one of the hand winch.
/ Truck Tires for a Trailer #7
For that style trailer that you describe as a "beater" I would just put the used truck tires on and and get a spare or 2. would defintely try and get 10 ply or load range E or heavier though. If you were talking about a gooseneck or heavy equipment trailer to use a lot and heavily loaded I would hold out for the trailer tires. If you use your "beater" trailer like I do the tires will probably need replaced from rot before you wear them out. I like the way you have the trailer set up, I wouldn't paint the rims though, you might like the look so well you have to paint the whole thing;) and then you be afraid to use it.:p
/ Truck Tires for a Trailer #8
I ask that my trailer tires hold air and all be very nearly the same size. I get used truck tires and run them until they self destroy. I have two spare rims/tires for my trailers so when they come apart I can solve the problem. Like you, I can get a used tire, mounted, for $25, from a local tire shop. The owner keeps only tires with relatively new dates and adequate tread. A trailer on my place doesn't get lots of miles so purchase new is not cost effective.
I actually noticed tonight as I was checking the tire size that the current tires are "P" tires. So I have passenger car tires on it right now. E-load range truck tires will be a big improvement.
I don't use this trailer a ton, but I'm using it more than what I had before. Eventually I do plan to paint the whole thing and re-deck it, but it's going to all happen gradually. I also need to get a break-away battery installed somewhere too. I have already re-wired all of the lights, and I've replaced the jack. I also had to gather parts from all four wheels to get one axle's worth of brakes working. Including purchase price and all of the parts I've bought to fix it, I'm still under $300 for the whole thing.
I need to get a spare. Any suggestions on the best way to mount a spare on a flatbed like this?
/ Truck Tires for a Trailer #10
To mount your spare get a $10 U bolt made for mounting spare tires. The tire will simply lay flat on the center beam up near the tongue and the U bolt will go around it. The tire will balance by laying on all 3 pieces of the tongue near the coupler.
The only other way I can see is to weld a upright with a angled brace. Then weld on two studs at the proper spacing to accept the tire.
Chris
/ Truck Tires for a Trailer #11
Hey Iplay,go on craigs list and search auto parts.I have seen in my area a set of used e load range 10ply trk tires going for around 100 bucks. Maybe theres a good deal in your area!
I'm already connected. I have a close friend that runs the local tire recycler. He can usually get me any size I want for $10 each. Most have more than half the tread life left, and some are even better than that. I run used tires on all of my vehicles.
I also have connections with a guy who is on the fire department with me. He works at the local farm store, and if I catch him during a slow time of day he'll mount my tires for free. He's not really that good at balancing tires, but on trailers it shouldn't matter that much.
I called my tire recycler friend last night to give him my tire size. He said he may have some trailer tires in the yard that are that size. If he doesn't, the next best options are a size up or a size down.
/ Truck Tires for a Trailer #13
Heck,with prices like that,go could go in the used tire business,as long as your supply holds out!
/ Truck Tires for a Trailer #14
For the money, the truck tires sound like the ticket. Load range E tires are the way to go if light truck tires are being run close to their capacity. I also believe that the truck tires are most likely a better rubber compound.
/ Truck Tires for a Trailer #15
Load range E tires are overkill for that trailer. Since you can get the tires cheap, I would just get a set of 4 tires of the same size that have a load capacity of 1750 lbs minimum each and you will be fine.
/ Truck Tires for a Trailer #16
I have a RV trailer and belong to the forum rv.net. In those discussion groups for RV trailers, it's generally considered a good upgrade to trade up the trailer tires to LT tires.
There are lots of entries in those forums about it and there almost all positive.
Larry
Larry
That's valuable info. Thanks.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
