Griffin Dump Trailer Issues Never Again
/ Griffin Dump Trailer Issues Never Again
I think most trailer manufacturers spec the cheapest components that will carry the rated load, nothing more. I don't know what you were sold, but you might want to recheck the rated load capacity. The capacity I see on their website for the GT612 6'X12' dump is 6,000# load capacity. I don't see an option to upgrade load capacity, just a jack increase from 7,000# to 10,000#. That might account for your excessive wear. Also check the load rating for the tires. It doesn't list a rating on the website, just 15" radial tires, but they may have been Load Range D 8-ply tires. That would barely cover the GVWR of 9,990# with 6,000# of payload weight. If that is so, I would up that to a Load Range E 10-ply if it were my trailer.
/ Griffin Dump Trailer Issues Never Again #22
That's good, at least you have heavier axles and larger tires than their current offering. It sucks the other suspension parts were not up to the task. But once you get them replaced you should have a decent working trailer. Out of my 5 trailers the dump trailer gets the most use.
/ Griffin Dump Trailer Issues Never Again #23
No, it's got 2x6k axles, rated for 8K payload. The sticker on the trailer also says so.
I am guessing they de rated them after poor performance.
Curious:
6k axles but they don't equip them to spec?
It came with 16in 8 lug wheels and the cheapest E rated tires I've ever seen.
/ Griffin Dump Trailer Issues Never Again #25
If you bought this trailer new and already broke it,
Me thinks you bought too cheap for the job.
That’s a lot of issues with a new trailer.
Perhaps being overloaded was the culprit?
/ Griffin Dump Trailer Issues Never Again #26
I will soon be in the market for a dump trailer. It would be helpful if folks posted tips for finding a quality brand.
/ Griffin Dump Trailer Issues Never Again #27
It is rated to haul 8K. Most of what I have been hauling is gravel I have bought at the quarry. They weigh in and out, so I've only been over 8k a couple times by a few hundred pounds.
The tires that came on it had a max rating only a couple hundred pounds more than the loaded weight of the trailer.
As I pull it apart, I see all plastic bushings and no greasable bushings.
I will be upgrading to brass and greasable.
I have no complaints on the actual trailer and hydraulics. My issues are the light duty tires and suspension components.
You never want to go to the maximum weight. An extra run or 2 to the quarry would be worth it.
/ Griffin Dump Trailer Issues Never Again #28
Ran 6 loads of gravel with my neighbor's 5x10 over the past week, zero issues. 2-yard loads of gravel are so meager, really sucks not to be hauling more - but would rather be safe than sorry and my landscape supply shop is just 5 miles away and only two intersections.
It basically doesn't even have a brand name on it anywhere, he bought it locally.
/ Griffin Dump Trailer Issues Never Again #30
I have a Griffin 6x12 Dump trailer I purchased new in June 2024.
Updated pics to show trailer rating
The battery lasted about 3 months
The tires lasted about 4 before they were coming apart.
I just broke a spring last week, not covered by warranty.
I took the suspension apart and found the bushings had all failed, the equalizers are worn out of round, the links are also worn out.
Are these made as though most people would not actually use them much?
That seems to be a common problem with Lippert components.
/ Griffin Dump Trailer Issues Never Again #31
The fact that only one side of the shackle for the leaf springs is worn kind of tells me that it's not an overweight situation. How did your tires fail?
I have never owned a trailer with anything other than plastic bushings in there and they wernt greased. The last one I took appart had worn out plastic bushings in there. After 15yrs you cant expect to not need to replace parts. However 1yr of use I wouldnt.
Maybe this is why Dexter is the standard in trailer parts?
/ Griffin Dump Trailer Issues Never Again #32
I'm guessing they de rated after poor performance.
They didnt de rate anything. Theres typicaly two axles. 6000x2 is 12,000lbs
/ Griffin Dump Trailer Issues Never Again #33
It is not Lippert or Dexter parts that fail or don't fail. It is the trailer manufacturer that is in control of the suspension specs. Economy trailers might spec this type, first picture. In my opinion,10k or less. For 12k-16k the second style is preferred.
/ Griffin Dump Trailer Issues Never Again #34
They sell to a price point for sure. Griffin is a very common brand around here if you view the local trailer dealers offerings. They have a 5x10 7k dump in what I would call a homeowner class that was listed on a lot of dealer sites for $5200-5500 last year. Just over $5k is pretty inexpensive for a new dump trailer. It's clearly built lighter than many both in reinforcing and axles 2@3500lb - you can find other brands with that small size getting closer to $8k price tags when they build them heavier. Used rotted steel ones are often 3-5k here. Even knowing what I know, I've toyed with getting one and dealing with the shortcomings. I work a lot and it's hard to schedule / hire other people to do stuff when I need it - Often it's more convenient to buy it and have it whenever the need arises. pretty easy to sell & recoup a reasonable amount of the initial cost. Since I have a 1/2 ton, buying a bigger one won't let me haul more in a single trip anyways.
