pto runs counter clockwise
/ pto runs counter clockwise #1
hayman1123
I have recently purchased a mitsubishi d1500 and the pto runs counter clockwise (reverse). I am needing to use a brush hog with it if possible. What do I need to do to make this possible. Is it safe to turn the blades over so while the pto is backwards, will it still cut. Is it safe to use a brush hog with the reverse pto.
Thanks
/ pto runs counter clockwise #2
Depending on the brush hog I've read where you can sharpen the backside of the blades.
If you search hard enough you may find a reverser, but expect, if available (likely only used) to pay big bucks, somewhere in the $500 plus range.
Or, not sure if ever made, you may find reverse spinning brush hog.
I had a Kubota B6000E (two of them actually), I found the reverser for it which converted to six spline clock wise spin.
I also had the original tiller and finish mower which were both reverse spinning.
Joel
/ pto runs counter clockwise #3
Joel nailed it.
Here's the reverser he was talking about on the back of my B6000E.
/ pto runs counter clockwise #4
One would have to ask......... especially with a company as competent as Kubota, what the heck were they thinking ?????? :mad:
/ pto runs counter clockwise #5
Farmall Cubs and some Kubota;s also ran CCW I was looking for a gearbox for a cord wood saw one day a few years ago and while thumbing through a catalog I saw a reverser for Cub and I think Kubota,If I remember right it was Horton and was sold by Eastern Bearings.
/ pto runs counter clockwise #6
yep.. and I've seen a brush hog mower setup to spin backwards as well.
couple options.. all expensive though! or lots of wrenching.. IE.. finding a mower that has flat blades / blade carrier that you might get away with flipping them.. and then assume the gearbox likes it... not to mention it will be hard to find a reverse ORC..
hope the tractor was cheap!
soundguy
/ pto runs counter clockwise #7
I'm not sure how you are looking at your PTO. Standing at the rear of the tractor, at least on mine, [Int.454 1972] the PTO rotates ccw, the revers of the engine. I just checked with my repair manual to make sure. I'm perty sure that ccw is the standerd for AG tractors. I will check this out tomorow, just to be certain.
/ pto runs counter clockwise #8
If the tractor has a smaller, non-standard PTO output shaft, the speed may well not be the 540 RPM standard. You should look into that. Bush Hog and other cutter manufacturers have multiple spindle rotaty cutters with counter-rotating blades. Maybe you could match up blades the same length, thickness and shape that are a mirror image of yours.
/ pto runs counter clockwise #9
Most of the machines with CCW PTO's are gray market tractors that where never ment to come here. The B6000 is one of only maybe 2-3 models with CCW PTO's that Kubota did bring here themselves... but this was 30-35 years ago before this market had even begun to develope.
/ pto runs counter clockwise #10
Rats, I checked out the rotation of my PTO, It's CW, I've been under the hood fixing engines so long that I think of them as turning CW, not CCW as vied from the back witch makes my PTO the reverse rotation of the engine CW.
/ pto runs counter clockwise #11
I realize that this is an old thread but there are 1:1 ratio Parallel Shaft drives made by Hub City. They are used by several manufacturers as their OEM supplier.
/ pto runs counter clockwise #12
Okay, I'm confused. If I'm standing behind the tractor, which way should a NORMAL PTO shaft turn? CCW or CW?
And is this generally with, or against, the direction of the engine's rotation--again, while viewed from the REAR, for consistency.
Thanks much.
/ pto runs counter clockwise #13
Standing behind the tractor looking at the PTO a "standard" PTO turns clockwise which means "standard" attachments take a counter-clockwise input (looking at the input shaft going into the implement which is opposite looking at the rear of the tractor of course). I'm not sure if there is a "standard" engine rotation, but all of my tractor engines rotate counter-clockwise as viewed from the rear of the tractor. Which then means if I walk around to the front of my tractor and look at the front PTO directly coming off the engine, it rotates clockwise.
