Tarp System for Dump Truck
/ Tarp System for Dump Truck #1
Jeff244
Southern IL
Kioti DK 65C
Does anyone use a tarp system for their dump truck? I want to buy one for mine but there seems to be so many different ways to go. I thing the arm system might work best for me. Although I am a little worried that I could damage it when loading the truck. I plan on mainly hauling gravel, dirt and probably some cut up trees also. Anyone have any company or system that they would recommend?
Thanks,
Jeff
/ Tarp System for Dump Truck #2
It's a pretty crude system but it works very well. The previous owner of my F-350 dump truck took some heavy canvas which looks like it was made for a cargo cover and tied one end to some 2.5" PVC with a 90 degree bend on the end held on the bed with some huge U brackets. The other end of the cover has a small PVC pipe through the canvas with an eye hook in the center. I pull the cover over the load and use a bungee cord to tie it to the back of the tailgate. When I am done, I hop in the back and wrap up the cover with the PVC handle, use the same bungee cord to tie it to the window grate and it's out of the way.
Click thumbnails for larger images
/ Tarp System for Dump Truck #3
Thanks,
Jeff
Jeff, here's mine. I like it and it has given me no troubles. Funny thing is, I can't remember the brand, but it's probably a Pioneer or a Donovan. I suggest aluminum construction.
Thanks for the replies.
Builder, the system I want is just like the one you have. I have found their websites and will call them next week to get some more info. It looks like it will cost between $700 and $1000 depending on which way I go. Do you know how difficult it is to install one of them?
Thanks,
Jeff
/ Tarp System for Dump Truck #5
Thanks,
Jeff
Even if you're only an average mechanic, you can install it in about 4 hours. It's pretty easy.
/ Tarp System for Dump Truck #6
rollright tarp and areo tarp company's make great systems for your application i would check them out on the net
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
