Problems with my B7800
/ Problems with my B7800 #1
chinawall
1. Breaking too many shear pins on front end blower
2. Doesn't always start in cold weather
3. Thorns puncture tires
4. Fuel gauge, lights don't work
5. Tried replacing front lights but "gasket" disintegrated
6. Lots of plastic
B78000
235 hours
6. Lots of plastic
B7800
235 hours
:mad::confused::eek:
/ Problems with my B7800 #3
Is this a "I'd like some help post on how to prevent this from happening in the future" or "Kubota sucks post"?
You'll gain respect and advice from others if your posts are made in a NON ACCUSATORY way.
/ Problems with my B7800 #4
Maybe its time to move to the City... Pushing a shopping cart home is good exercise and results in minimal damage to the equipment. You will be able to ascertain whether its the cart or the pusher...
/ Problems with my B7800 #5
Most B7800 owners seem to be quite pleased with their machines?
I guess one has to make it really simple for you guys.
Actually, I was looking for advice. I forgot to bow!
/ Problems with my B7800 #7
Sorry I wasn't trying to be rude but if you look at your first post it just mentions the issues and no request for assistance. At times in the past people have just slammed a color or model out of frustration.
For example you say it won't start in the cold. Ok,
is it outside uncovered in the cold weather
how cold is it when it won't start
how long do the glow plugs prime for before you start
did you change the fuel filters, add diesel addative ect...
The more info you offer the easier it is to help.
No bow necessary....
Don't let my fruustration get to you! Maybe you need some help yourself.
/ Problems with my B7800 #11
I have a B7800 and my only problems have been "Mike-made".
1. Breaking too many shear pins on front end blower Lots of grease, make sure you're not shooting gravel, slow down if necessary. Shear pins are WAY cheaper than other parts.
2. Doesn't always start in cold weather Run the glow plugs longer. Clean fuel filter - making sure you don't have an ice jam
3. Thorns puncture tires Locust thorns can certainly do a job on tires. Even multi-flora rose if you're unlucky. This is one of the reasons I opted for the much disparaged R4 tires - less area for thorns to get into the thinner rubber. If you see this as a continual problem, consider foam-filling your tires.
4. Fuel gauge, lights don't work I had this - found that mice had made a nest under the dash and had some wire insulation for lunch. Fixed wire, sealed space, all works fine.
5. Tried replacing front lights but "gasket" disintegrated I can see this as a frustration.
6. Lots of plastic Did it have plastic when you bought it, or did some of the metal morph? :)
B78000
235 hours
/ Problems with my B7800 #12
I don't get it. The B7800 is probably one of the most reliable, efficient and well-thougth out tractors ever built. It is remarkably trouble-free and if it were around 100 years ago would have drawn crowds from surrounding states to marvel at it's abilities. It could have worked a 60 acre farm and taken holidays and weekends off.
No way, Lefty. I got over my tantrum.
Thanks Mike.
Should I run it at 540 rpm's? If I run slower, would it still break shear pins?
/ Problems with my B7800 #15
6. Lots of plastic
B78000
235 hours
1. Don't have a snow blower...don't know the answer...problem with blower, not tractor?
2. Use power service additive or something similar to prevent fuel gelling. Put a block heater in and use it. No problems at all at my end with my B2910...
3. Foam fill your front tires. No problems at this end after the first couple hours I had my tractor. Rear tires don't seem to be a puncture issue. Which end is your issue?
Dont' know about your other issues as they are not issues for me...B2910 may have some differences from yours...about 800 happy hours here...
Hope this is of some help...
/ Problems with my B7800 #17
Make sure the shearpins are for a tractor instead of a walk behind snowblower. When I got the wrong batch of shearpins I could break them if I engaged the pto to quickly.
/ Problems with my B7800 #19
Hmmmm,
Added power service, no jelling problems.:)
Use the glowplugs for longer than I think I should, starts right up.:)
No problems with the lights.:)
D mn neutral sensor switch on the treadle needs to be fiddled with every once
in a while.:mad:
Very little plastic on my 7800.:)
The only thing that would make me happier is a cab.:D
Bill
/ Problems with my B7800 #20
1. Breaking too many shear pins on front end blower - I had a problem with rear blower breaking pins so I just started taking it easier on the icey snowbanks
2. Doesn't always start in cold weather - Mine came with a block heater-no problems even at -30C
3. Thorns puncture tires-I have R4 tires and use my B7800 for forestry work-no problems with tires
4. Fuel gauge, lights don't work-no problems with mine-maybe a fuse problem
5. Tried replacing front lights but "gasket" disintegrated - I have replaced my front bulbs with 50 watt halogens-works great
6. Lots of plastic- not mine-even the hood is metal
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
