Insulate/Upgrade Existing Pole Barn/Shop
/ Insulate/Upgrade Existing Pole Barn/Shop #1
survriggs
Missouri Ozarks
Kubota B7800
Hello all! I'm considering a project on an existing pole barn and thought I would ask some advice from TBN'ers. It's a typical pole barn, metal siding and roof, 24x36x8 tall with trusses on 8 ft. centers & concrete floor. I'm wanting to insulate walls and ceilings. The trusses have held up for 22 years but with the added weight of ceiling and insulation I plan to build extra rafters in place so they will be on 4 ft. centers. I will then add 2x4 purlins (if that's the correct term) between the ceiling joists to nail 4x8 osb to. I would like to blow wood cellulose in ceiling but am not sure if the weight of the ceiling and wood cellulose will be too much. I then plan to add studding on 24" centers and use fiberglass insul. and vapor barrier on inside and then use osb for walls.
Question #1: Am I addressing the structural ceiling issue correctly?
Quesiton #2: Any better ideas for insulating walls?
I'm sure I will get some different ideas and I welcome any and all. I've included some pics. I really enjoy the progress pictures that I see on TBN and when I finally decide which way to go I will keep progress pics uploaded if anyone would be interested. This is a great site and I've really learned a lot.
Ralph
/ Insulate/Upgrade Existing Pole Barn/Shop #2
I think you would be very happy with that method. I am doing exactly what you describe to my new 40X40X15. I just ran 2' centers across the span between trusses that are 8' apart.
One thing I think you should plan for is venting the attic though. At very least, a ridge vent and some spot vents to get moist air out and vent hot air in summer.
Conservation: If I can be assured that the 8 ft. span will support ceiling + insulation I will do exactly what you suggested....be a lot less work. What kind of ceiling material and insulation are you using? Also, since I am replacing the light panels in the roof anyways, I can ventilate it somehow at that time.
/ Insulate/Upgrade Existing Pole Barn/Shop #4
Ralph it looks to me like the bottom cord of your roof trusses are 2x8, is that the case? If so I think you will be fine with the added weight. I would run 2x4 purlins vertically like was done for the roof panels.
MarkV
/ Insulate/Upgrade Existing Pole Barn/Shop #5
... 24x36x8 tall with trusses on 8 ft. centers & concrete floor. I'm wanting to insulate walls and ceilings. The trusses have held up for 22 years but with the added weight of ceiling and insulation I plan to build extra rafters in place so they will be on 4 ft. centers. I will then add 2x4 purlins (if that's the correct term) between the ceiling joists to nail 4x8 osb to. I would like to blow wood cellulose in ceiling but am not sure if the weight of the ceiling and wood cellulose will be too much. I then plan to add studding on 24" centers and use fiberglass insul. and vapor barrier on inside and then use osb for walls. ...
Ralph,
Can you post some pictures of the actual truss?
By building another truss in between the existing one, and then adding purlins to the trusses, you are probably going to be fine. It sounds like allot of wood and money to go this route.
The 8ft spacing of your trusses makes it hard to span the distance between them to add OSB, so I'm wondering if you've considered using metal R Panels?
Your building is 24 feet long, so you could buy the panels in 12ft 6in lengths and screw them into your bottom chords. Overlap the panels and screw them together will make them plenty strong. If the trusses are engineered, they will be able to handle the weight. If they are not, it's anybodies guess.
You could add the insulation from the top when you replace the skylight panels, or you can do it as you go. I prefer blown in insulation since it's cheaper and you get total coverage. Home Depot and Lowes both let you use the machine for free if you by ten bags of insulation.
Depending on your ridge cap, you might find it easier to vent the attic space by cutting and installing gable vents on both sides of your peaks. This will give you good cross flow of air through your attic. Wind turbines are OK, but not my favorite. A good peak vent for metal roofs are usually pricey.
This is exactly what I plan to do in my shop. The only difference is my trusses are on 4 ft centers, but they are not as big as yours. The cold is killing me, not to mention the short days. Being able to work out in the shop when it's freezing outside would sure be nice.
Eddie
Eddie:
I have attached a pic of the truss. They are engineered 2 x 6 trusses. I like your idea of putting purlins between and adding metal for a ceiling. It would make it a lot brighter. I'm still a little hesitant to rely on the 8 ft. span between trusses; I would rather be safe than sorry...it may just take me a little longer to build up the piggy bank. (it's been uninsulated for 20 yrs. - another few months won't hurt) I think I'm going to also look into pricing it for the walls also. How had you planned to cover and insulate your walls?
thanks for the advice,
Ralph
/ Insulate/Upgrade Existing Pole Barn/Shop #7
I haven't decided on thickness, but OSB for the ceiling.
The metal is a great way to go also. The problem is the cost. It was three times as much when I checked, and even when I added the extra cost of the wood 2 by's, it was still twice as much. Metal makes for a much nicer interior, and they have interior grades that aren't quite as expensive as exterior.
/ Insulate/Upgrade Existing Pole Barn/Shop #8
Looks like you have some very strong, well built trusses. No worries there.
I'm just guessing here, so it might not work, but I don't think you need any purlins with a metal roof. It only has to be strong enough to span 8 feet and the insulation. The ridges on the panels should be able to span the distance, and with screws, you shouldn't have any problem supporting the weight of the insulation.
The walls in my shop are covered with OSB. I don't have any insulation in the walls. I'll never cool the space, I just want to be able to heat it a dozen times or so in the winter when I want to do something out there, but it's too cold. Doing the ceiling should be a simple, fairly inexpensive way to accomplish this. My biggest delay is trying to decide what to use for the heater.
I also noticed light at your peak. Do you already have a ridge vent? If so, then your set for venting!!!!
Eddie
/ Insulate/Upgrade Existing Pole Barn/Shop #9
I haven't priced it out for myself lately, but...
For the walls, you might price out foam panels to nail to the existing purlins, followed with osb.
Sounds like you guys have the ceiling covered.
Eddie
The only venting is the spaces created where the topcap and the metal meet. I've attached a drawing of two options that I'm looking at for the walls. Any opinions welcome.
  • 3731_0001.pdf
2023 Global Trailers GT302 60YD T/A End Dump Trailer (A59230)
2023 Global...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
