Snow Plow, Front or 3pt Hitch
   / Snow Plow, Front or 3pt Hitch #1
alltoys
Vimy, Alberta
Montana R28
What is your preference? A front snow plow mounted to a FEL or to the front frame of the tractor? Or a 3 pt Hitch type with the FEL bucket on the front to move snow to a pile?
   / Snow Plow, Front or 3pt Hitch #2
For a gravel drive, and if the snow isn't too deep, I'm finding that a rear blade with gauge wheels seems to work a lot better than I expected. With that setup, I'm able to get most of the snow off without taking much gravel.
   / Snow Plow, Front or 3pt Hitch #3
A plow on the front is not only easier to control, but wieght transfer, especially if the tractor is 2WD, favors front mount. We used to plow our farm lane with a tractor equipped with an eight foot front mounted plow AND eight foot rear-mounted blade. Most of the time, we used the rear blade to pull snow away from garage doors, etc. It was nice to have the rear blade for ballast, too.
   / Snow Plow, Front or 3pt Hitch #4
I have a BX23 with FEL and a BX1500 with a frame mounted front blade .
   / Snow Plow, Front or 3pt Hitch #5
My preference is a frame mounted front plow, I tried the FEL mounted plow with poor results.
   / Snow Plow, Front or 3pt Hitch #6
If you FEL mount a plow so the blade will float you will not have any problems. The FEL becomes the 4X4 truck and it stays at one height while plowing. Works for me.
   / Snow Plow, Front or 3pt Hitch #7
If you had of floated the blade instead of that solid mount the we seen in here is would have worked very well for you.
   / Snow Plow, Front or 3pt Hitch #8
There is no doubt which I would prefer. I have no need for a FEL in the winter. If you get a lot of snow regularly, you would want an arrangement like this:
   / Snow Plow, Front or 3pt Hitch #9
I am not convinced of this...For my small tractor, the plow ended up to far in front of the wheels.
   / Snow Plow, Front or 3pt Hitch #11
I had a front mount blower on my CUT but each time that I wanted to go into my woods to do logging it was a 2 hour change over to the FEL. I even mount a blade in place of the blower but I had no ground clearence. I like what I have now and it works very well on my 1/2 mile driveway. You guys are right however , it does set out in front of the tires quite a distance.
   / Snow Plow, Front or 3pt Hitch #12
I had a frame mounted front blade on my old 850 and it worked great for a 2wd. I upgraded to a 4wd and went with a FEL mounted plow for the same reasons as Deelope describes. The FEL blade can be swapped out for the bucket in seconds, and can also be raised higher to push large piles back. My blade floats too, and once the gravel is solid in the winter I have no problems with it. The frame mounted blade gives you much better control if you have dips and contours to your drive though. Either one is much better than a rear mounted blade if you get much snow.
   / Snow Plow, Front or 3pt Hitch #13
I have tried many combinations and found that 'straight line push' frame mounting to be best.
The blade attached to a loader will cause your front te become very light and unsteerable as the arms push upwards.
Since I mounted my blade with the arms pivoted on my subframe I can steer a load of snow to where I want it to go.
Also I angled my blade to the right and can plow flat out in 3 gear with complete control .
My little Mitsubishi is but 48" wide and 20 hp but handles my 6' blade no problems, like I said, flat out in 3rd gear!
Once I have gathered all the snow to one side of the drive with the blade I make a pass with the rear blower and blow it away into the forest.
   / Snow Plow, Front or 3pt Hitch #14
I'll cast my vote for the frame mount front plow. I also use the box blade on the rear for extra weight to scrape and pull snow.
   / Snow Plow, Front or 3pt Hitch #15
Would operating the FEL in float not prevent this? You guys got me worried. Supposed to take delivery of my quick attach (FEL Mount) front plow tomorrow.
   / Snow Plow, Front or 3pt Hitch #16
It did not help for me...basically what happened is as the blade filled will snow and the rear kept pushing forward, then the front wheels would get light. You can try the same thing in a dirt pile-drive in and keep pushing, the front wheels will come off the ground. When that happened, you could lift the blade to add more weight, but then you are not plowing all the snow and then driving over what you missed.
I think the people who have had great success with there's have muck larger/heavier machine than mine...
   / Snow Plow, Front or 3pt Hitch #18
I've lived at the same place for 25 yrs. Blacktop drive is about 100 yards long, plus a large parking area near the house, and along the front of my 30' x 45' pole shed.
The first ten years I used an 8n with a 6' blade, always plowing in reverse. It did OK, and I never bent anything, but it was a pain in the neck (literally). The next ten years I used a 4x4 truck with a 7.5' hydroturn plow, and if I could afford to drive one, would still be going that route today. The last 5 years I've used a '65 Ford 2000 with matching FASCO loader - 7' snow bucket, no downpressure, clumsy as ***, 2wd w/chains and ballast box. Had 100+ inches of snow last winter and it did just fine, but wasn't ideal.
I enjoy using the loader, and don't mind the little extra time it takes if it means the snow ends up where I want it to. Seat-time is seat-time after all.
Time will tell if my 3510i with a 6' bucket and 6' box-blade will prove to be the answer to my snow-removal needs, but I think it'll do just fine, and am looking forward to a lot of snow this winter (I know - sick).
   / Snow Plow, Front or 3pt Hitch #19
Thanks for the clarification. I'm using it on a DX45 with loaded rear tires. Tractor weight is 4,000 lbs + and blade weighs just under 700 lbs so I should be fine.....I hope.
   / Snow Plow, Front or 3pt Hitch #20
Here are a couple pics of my FEL plow on my DX55. I do not run the FEL in float since the blade floats on its own. I raise the loader until it starts to pull the blade off the ground, then lower it a few inches. That keeps all the weight of the loader on the tractor, and only the blade istelf is floating to follow the contours of the drive. Early in the season when the drive is mushy, I hover the blade with a fine touch on the loader controls and skim just above the gravel so I don't tear it up. This blade is a monster and really moves the snow with ease. The FEL curl/dump controls come in handy letting me pull the top back so the blade rests on the shoes, and rolling it forward slightly to use the cutting edge on paved areas.
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
CFG Industrail MX15RX (A53317)
CFG Industrail...
