yet another electrical question
/ yet another electrical question #1
gspig
Can romex uf-b be buried in the ground without being in conduit?
/ yet another electrical question #2
I am under the assumption that the "UF" designator is for Underground Feeder cable, and therefore is direct bury.
Dave
/ yet another electrical question #3
Type UF cable can be direct buried as long as it's not embedded in poured cement, concrete, or aggregate. Minimum burial depth in a residential setting is 18". Reference Article 339 of the National Electrical Code.
/ yet another electrical question #4
Check Article 300.5 of the NEC®. I think you'll find the minimum is 24" through the yard unless GFCI protected and under 20A, then it's 12". Also minimum 18" under a driveway or parking area at a residential location.
Article 339 no longer exists, but Article 340 covers UF cable and refers you to 300.5 for burial depths.
/ yet another electrical question #5
I gave up using UF. I find using conduit and the ability to add or upgrade wires and the extra benefit of added protection enough reason to use it. I also find using UF a pain to make up in the boxes.
/ yet another electrical question #6
Edit previous post
.......GFCI protected and maximum 20A overcurrent protection
/ yet another electrical question #7
UF sux to work with, besides, PVC burial depth is 18" vs 24" for UF.
/ yet another electrical question #8
don't forget to protect all penetrations in & out of the dirt and or buildings. also requires marking tape buried 12" above wire buirial depth.
Mark M /forums/images/graemlins/wink.gif
/ yet another electrical question #9
Not sure where you are at, but if you have any sort of gophers, moles or ground squirrels, etc... then it's just a matter of time until one of them decided to chew on the insulation. All sorts of cheap conduit available, you don't need anything special, just something to keep out the rodents.
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2022 North Star Pressure Washer (A60352)
2022 North Star...
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
