Yanmar red paint code
/ Yanmar red paint code #1
GeoffDeering
British Columbia, Canada
Yanmar f17d
I intend to paint the hood and engine cover of my F17D, also a few touch ups elsewhere. Most of it doesn't need repainting, a good cut polish will suffice. I shall use car type paint, the acrylic enamel that uses a hardener.
My question is, is there a manufacturers code number that I can ask for that is a good match? It doesn't seem likely that I will be able to get Yanmar red as such, but quite likely that a particular red from a make and year of car would be correct.
As various members have repainted their tractors I am hoping that this is a frequently asked question.
Thanks for any advice here,
Geoff
/ Yanmar red paint code #2
Geoff,
I am not aware of the correct Yanmar factory paint code. It has been my experience that factory batch paints vary slightly anyway....plus air pressure, viscosity and catalyst further change the color.
A small (good clean) panel from your tractor can be color matched - electronically scanned at your automotive paint store, like DuPont or PPG. Almost always, the results are excellent. Good Luck.
Mark
/ Yanmar red paint code #3
I used Ford Ranger Red when I repainted mine, it wasn't that close, but since I did all the sheetmetal it didn't matter, and it'll be easy to buy touch up paint later. Another Yanny owner did his in massy red.........
/ Yanmar red paint code #4
There is no factory paint code for Yanmars, at least, available outside Japan; however, most guys remove the panel under the dash and take it to be scanned. It is usually like new, easily removed and easily scanned.
Thanks for the input guys,
Looks like the best thing to do is get a panel colour matched at a good pro store, then.
Cheers
Geoff
/ Yanmar red paint code #6
GeoffDeering:
The last time I checked you could still get Yanmar red from a supported Yanmar dealer witch in turn comes from Martin diesel who is Yanmars parts supply here in the good ol’ USA. But, you will pay through the nose for it……..
/ Yanmar red paint code #8
Jagmandave:
Yep, sure did. Massey red from Tractor supply store
/ Yanmar red paint code #9
Whisky,
How did that paint work out for you? Any problems? How has it help up since you painted it? Just curious.
Mark
/ Yanmar red paint code #10
Mark:
The paint is like a coat of armor, I'm am inpressed.
Had the rear wheels sunk up to the axels in mud a while back and thought for sure I would scuff up the white paint on the rims spinning the tires.......not a mark! A couple of light branches have rubbed down the side of the hood while hoggin'.....not a mark from that either.
Whipes down with water and shines like it was painted yesterday!!!!
I'm tossin' around painting my truck......maybe a little over my head.....still thinking about it.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2013 Chevrolet Impala Sedan (A59231)
2013 Chevrolet...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
