XG3025 Recall
/ XG3025 Recall #161
Your best tool should be your thought process.
Attack your task w/ thinking first.
My wife is the boss here, but I help her w/ the problem solving.
Always trying to figure out where she put the chain saw.
Kidding aside, our tractors are not built for any single task but get pressed into all kinds of service.
Only the operators make mistakes.
Much thanks for sharing your events. I learn for everyone's post.....it's cheaper & hurts less.
/ XG3025 Recall #162
Okay Now, Just off the phone w/ an LS representative.
This concerns the adding of the turn buckle or linking the upper back connection to the XG3025 LS tractor to the LS 1100 back hoe.
DO NOT link your back hoe (LS 1100) to your XG3025 tractor by this means. Here is a pix of our connection point from our XG3025H.
Sorry to be so graphic about this but our turn buckle link snapped in two.
The LS rep told us our back hoe is to have flex in the connection.
Adding this link could result in the cracking of the top of the transmission. This has happened in the earlier days.
My well intended LS dealer (not the selling dealer, now out of business) who did the recall attached this upper link.
Nothing happened bad, only the turn buckle snapped & not the transmission top.
We know we posted here pix of the addition of this linkage. Others have also expressed this desire to stiffen up the connection between tractor & backhoe. It did in fact stiffen the operation up, but those little blue connections on the backhoe are for transporting this back hoe only. They are not for operation of this back hoe.
We will be going back to my earlier post here in this thread, to edit those pix.
My dealer has offered to replace my turn buckle. We hope you folks will keep this info in mind & look out for it when conversing w/ other XG3025 owners.
/ XG3025 Recall #163
Big Blue it looks like you were lucky that the turn buckle broke before something more serious happened. Thanks again for the information.
/ XG3025 Recall #164
You bet we are.
Worked 3 hours w/ the back hoe today.
There sure is a difference w/ the rear seat moving around but in reality, its the entire back hoe unit.
Pine stumps sure are stubborn .
/ XG3025 Recall #165
Just an update:
After an additional 100+hrs the returned LS is working great.
No issues after the recall up grades.
Thank you LS
/ XG3025 Recall #166
Just an update:
Thank you LS
That's good news Big Blue Florida, my 3025 has been working great, it has completed every task I've put it to in our 45 acre woodlot.
/ XG3025 Recall #167
Just an update:
Thank you LS
Good outcome. LS seems committed to helping customers and building it's reputation. That's a very good thing.
/ XG3025 Recall #169
Found some new leftover 2018 XG3025 shuttle shift with FEL. Did this issue apply to 2018's? Any way for me to tell if it had the recall done?
/ XG3025 Recall #170
Adamjt, my XG 3025 is a 2018 model and it required the recall modification. My dealer told me it was only a matter of installing some shims where the engine is attached to the frame if my memory is correct. I can not see where the shims were installed so I guess you would have to have a dealer look at it. Wish I could be more helpful but that's all I know. I'm approaching 200 hours on mine and no problems.
/ XG3025 Recall #171
Thanks. Dealer said they are doing frame and loader stanchion updates to them. Huh
/ XG3025 Recall #172
Would this include the xg3032 ?? Ive got a cracked block at 620hrs and dealer says it could be from stressing the front loader
/ XG3025 Recall #173
Does this include the XG3032 ? Have a cracked block at 620hrs use and dealer is telling me its from stressing the front loader
/ XG3025 Recall #174
E, I don't recall the 3032 being in the recall but it's possible I guess. I'm doubtful that stressing the FEL would cause the block to crack. If you bought it new I would think it's covered in the 6 year warranty. Good luck & please let us know the outcome.
/ XG3025 Recall #175
I cannot advise about the 3032, nor will I speculate.
But as far as just a shim replacement as posted by another fellow member here,. . . . . this I will step into.
There was a front frame change & a stronger mount for the FEL set in place. Plus more than a few other little bits of hard ware.
Might suggest going back a bit & look at some of my pix of my tractor taken apart by the dealer & the new major part which were added all under warranty.
This was a major under taking for LS & at this time I still am most pleased w/ how LS responded. OH YES, I WOULD BUY FROM LS AGAIN.
Something about stressing a motor block from a FEL: It all depends on the block of the tractor's motor; is it part of the frame support system?
You folks be safe out there.
/ XG3025 Recall #176
Hello Big Blue Florida, I just re-installed my backhoe about 10 days ago to clear a patch of land for a new shelter. I did go back in the forum files to see if I could find the photos that you mentioned in your last post. Unfortunately my search was unsuccessful, I'm sure it's there but i was unable to find it. When my dealer (a very knowledgeable and helpful person) did the recall on my 3025 he told me it was only the addition of some shims where the frame & engine meet. If there are additional frame parts that should be installed, I need to contact him again to see if he installed them. Also, in looking back at some of the old posts, I find several that recommend using a ripper in place of the bucket for stump removal, do you or maybe another forum member know of a source for a ripper that will fit on our XG3025 backhoe's?
/ XG3025 Recall #177
HEY ''fgsiii''
Check out page 17 & 18
Keep in mind, our LS is a 2016. This may or may not mean anything.
Our biggest or tallest trees were 100+ ft
These pines had stumps up to 42 inches diameter w/ tap roots beyond 6 feet deep.
We dug around the stumps & pressured washer the side running roots then chained sawed them .
Had to digg down under the stumps & wash out that area so I could get under that to cut the tap root.
Most of the time we just dug out some of the root & pulled that up.
It was our BH model # 1100 W/ small bucket on the business end that did most of the work.
Each stump offered up a different root configuration
No way our XG3025H could operate a front end ripper large enough to extract these stumps or even some of the side running roots as they too had their own tap roots.
Hope this helps
/ XG3025 Recall #178
Here are a few pix of our LS earning its keep .
These were taken just before the recall which we are talking about now, on the XG3025 for my 2016 model.
Since the complete work was done on our tractor we have continued to remove the same size stumps w/ no issues.
/ XG3025 Recall #179
Here is one more pix of the lower root cutting in order to remove the stump.
This tree is not a pine but an old sweet gum.
Perhaps on smaller stumps & lesser root systems a ripper on this size LS tractor might do the trick.
Our best to you & yours for a safe winter season.
/ XG3025 Recall #180
mine is a 2016 XG3025 all they did was put the shim in the frame , anyone can call your dealer and give them the serial number they can tell you if the upgrade was done , as i bought mine in 2019 with 62 hrs on it and the upgrade was done .
Jake
