woodmaxx flail mower?
/ woodmaxx flail mower? #181
I measured mine today, 57" offset from center of the top pin to the edge of the mower housing, and the blades cut about 1.5" in from outside of the end the end plate. I could likely get another 1"-1.5" offset out of my 3pt.
Hope this helps.
Very helpful, thanks. That means edge of cutters would go 20 1/2" beyond my tires. This may work.
I looked at some of the boom type cutters and their prices take your breath away.
Saw your other note on being able to hook to Cat 2, thanks. Any chance you could take a picture of your hitch? I may never use it on our 96 HP tractor but, would be nice option.
/ woodmaxx flail mower? #182
Betstco has 60-some inch ditch bank flails for about the same price as a Woodmaxx flail with side shift.
/ woodmaxx flail mower? #183
It may take me a day or two, but I'll do it first chance I get.
/ woodmaxx flail mower? #185
Just called Woodmaxx because my flail mower was suppose to be in yesterday. They told me it was delayed until next week, I had asked what day next week and they said they where not sure. Is this normal for this company? What I'm guessing is that they are to small to keep inventory on hand and just order from their Asian supplier as needed and if the supplier is delayed then you're SOL?
/ woodmaxx flail mower? #186
I assume that WoodMaxx does not work with dealers??
I wish they would offer an 84" or 88" version of their FM78H mower.
Presently their wider mowers jump up significantly in weight and HP requirement.
/ woodmaxx flail mower? #187
From my experience when ordering our 62H - Woodmaxx has mowers on order continuous, but manufacturing and shipping from China takes several months time between orders. The told me their different models are always on the list but how many and of which model is hard to plan for. Most are pre-sold as well. Keeping an expensive inventory is not good business it seems for most companies these days. Ours took about 10 weeks time from order date to delivery not bad either but we did order in early spring. Later in the year is longer perhaps. I like that ours has good weight and I expect it will hold up much longer than something light for its size ...Ours weighs 670lbs and 20 PTO HP operates it with ease in tall grass and brush...
Ricn
/ woodmaxx flail mower? #188
That's why I canceled my order...went from mid-July to late August. I hope the shipment comes in soon (for your sake).
/ woodmaxx flail mower? #189
So Roy, have you purchased another brand meaning, you have a flail mower now or, are you waiting until next year? With everything being an import these days it is hard to wait but what choices do we have? I tied buying the Caroni mower but they too were out of stock saying it would be August.
Ricn
/ woodmaxx flail mower? #190
I don't think they are too small, I think it is this:
Ricn
I had some delays in getting my Woodmaxx - it appears that the website time is when they expect the freight container to reach them, and the actual shipping date to you is 1-3 weeks later because they go through and inspect and partially assemble each unit. It's not a fast process, especially in this "Amazon prime" age. However, most tractor needs can be planned ahead, and a good implement should last years. After getting my mower and using it I'm OK with the delay, even if I would have preferred to just get it delivered the day after I placed my order.
It's just basic that items which are a better value (or seen as such) are in higher demand and therefore can be harder to get. I could have bought a different brand of flail and received it much sooner, but for nearly double the cost and without much clear benefit to me.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2013 Toyota Corolla Sedan (A59231)
2013 Toyota...
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
