Wooded loader platform
/ Wooded loader platform #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
Hey Y'all,
I need to build a temporary work platform for my FEL bucket to install barn siding on the back of my barn. I don't have but 20 feet to the fence behind the barn and cannot get my Mahindra 90 degrees off the barn's backside with the backhoe even turned to the side. You can check out the barn here if you want. http://www.tractorbynet.com/forums/projects/106272-my-pole-barn-solo-affair.html
I will be placing the 4x4s in the bucket and adding 2x6s over that. I will support all this from the chain hooks and the receiver tube welded to the top of my bucket. The 4x4s will sit into the bottom of the bucket. I used the bucket on the front side of the barn and the 7 foot wide bucket was nice to work from. So my question....Can I build a platform that sticks out 7 feet that will hold me and the weight of the materials, only secured by the chain hooks that are about 2 feet above the bottom of the bucket and a support from the receiver tube?
hugs, Brandi
/ Wooded loader platform #2
Just my two cents. Could you move the fence behind the barn temporarily to give you the room you need? Also how difficult is it to remove the backhoe from Big Red?
Wedge
Wedge
Wedge40,
The fence isn't mine. I could remove the backhoe, but I don't like leaving it out in the weather, as I need the barn space it and the tractor takes up to work The backhoe needs hard level ground to R&R. Removing the backhoe is very quick. But it takes a lot of prep getting all the blocks in place and also sometimes a bronc ride getting it off the subframe. I leave it on for counterweight.
/ Wooded loader platform #4
It would be easier and safer to rent some scaffolding and do the job using that.
/ Wooded loader platform #6
I will echo ToadHill and recommend using rented scaffolding. It is not too expensive and much safer. If you need something for Big Red to do then lay down two 2x12's as tracks and shove the stack along on top of them as you need to move it. One person can erect a two high stack without any problem. If you need to go 3 high near the peak you could use a helper to save all the climbing up and down.
Your ground looks level enough that you should not have any special problems in erecting and leveling a scaffold stack.
Vernon
/ Wooded loader platform #7
Brandi, I'm going to throw out another thought. Could you maneuver that fifth wheel trailer to the back side of the barn(lenghtways), then remove spare tire from the gooseneck and attach thick plywood to the gooseneck "V" and work from that height. Maybe it is too low yet, you can be the judge of that. The fifth wheel trailer would be moveable the lenght of the rear of the building as you needed. Just a thought, may not even be possible.
If you do build something for your receiver hitch on your bucket that extends outward, think of trianglar supports from bucket floor outward/upward out to the platform's edge. Just think of how steel framed bridges/trusses are supported. Lots of triangles.​
One more item; If you do build anything for your loader bucket, make sure you "test" it first with the loader only 4"-6" off of the ground and not 12 feet in the air. Walk to each corner, bounce around ,etc. You might even consider some sort of pipe hand rail feature above the platform, too.
/ Wooded loader platform #8
I'd be having a chat with the neighbour who owns the fence. Maybe offer to help fix up any other parts of his fence that need work in exchange for permission to temporarily remove that section.
I won't be moving a fence or erecting scaffolding. Moving the fence would take too long and too much extra labor. It is a woven wire fence intertwined with youpon and briars. She has goats over there and moving the fence would entail building another temp fence.
As the first attached photo shows, the ground is too uneven for scaffolding. Not to mention all the time calling to reserve it, pick it up, unload it, erect it, take it down, reload it, haul it back. Too much wasted time and the ground is too soft anyway.
The gooseneck is a lowboy. It would be major pain to move it back there anyway. As you can see in the photo, it is way wet back there.
The second photo shows the basic frame and the receiver tube with a check chain sticking out. It will have two chains supporting in and the back end wedged into the bucket with additional bracing. Oh yeah, it will have railing.
The third photo show the back of the barn from the other direction. Notice the tilt of my Mahindra and the fence row to the right.
I built the whole barn by myself, except for half the roof tin. I had some family and friends finish the other roof half when I had elbow surgery.
So thanks for all the suggestions.
hugs, Brandi
/ Wooded loader platform #10
Brandi,
I took your picture and crudely added to it. Take a look.
Add 2x6's to make a larger platform. That way you can work from either side.
Run chain or a strap from the receiver hitch on the top of your bucket out to the end of the platform to hold it up. Can't see it but I'm sure you are blocking the end inside the bucket to hold it down.
For sure, no matter what you end up with, take Catman's advise and test it thoroughly.
/ Wooded loader platform #11
Can you back the tractor out of the barn and be perpendicular to it? The only thing in the way then would be three poles. You might have to handle supplies different, but if there's room that might work.
Wedge
weldingisfun said:
Brandi,
Weldingisfun,:)
Thanks for the suggestions! How do you draw on the photos?:confused: I have wanted to do that before.;) I won't need a full 7 foot wide platform, which is the width of the bucket. At first thought, I was going to do that. But I figured since I only have easy access from one direction, I will just make the platform on one side. It's the KISS principle.;) It will have chains supporting it, similar to the layout in the photo below. I won't be using the full length of the platform. I will put handrails at 5 or 6 feet. No need go out that far as I would have to get down the ladder and raise the bucket anyway, so I can just move it forward at the same time. I left it 8 feet long because I didn't want to cut the boards and plywood shorter. Don't worry, it will get tested before I use it:D .
hugs, Brandi
Wedge
Wedge,:)
I can only back out of the barn and work about 10 feet. The barn is 44 feet wide. When I backed out the other day to hang the door track, I had the backhoe boom turned to the left and the dipper stick extended so the bucket would clear the fence. The bottom side of the boom still touched the fence and I still needed a little more elbow room to work good. My neighbor is the type that would say I strecthed her woven wire fence and wants me to replace it!:eek:
I was perpendicular to the barn while I sided the front of the barn. But I had to stand on the top lip of the bucket to install the top ridge screws. My only handhold then was the ridges of the siding.:eek: So since it is harder access in back, the platform will also have a step ladder secured to it to reach the top ridge. This is way more safer than standing on the bucket lip. I am not so much afraid of falling to the ground, which is mud right now. But if I fell backward over the bucket, it would be loader arms and hood that I hit. That doesn't seem too pleasant.:rolleyes:
Thanks!:D
hugs, Brandi
/ Wooded loader platform #14
You ARE close to the fence. I can't wait to see what you come up with. I could use something like that this spring (If it ever gets here). I have facia board to replace on the house. I hope you get some detailed photos when you have it finished.
Wedge
/ Wooded loader platform #15
weldingisfun said:
Brandi,
Brandi; You didn't acknowledge weldingisfun's statement about the blocking inside the bucket. I feel this is a critical safety item, that wood/platform must be held downward inside the bucket. Without this, the wood platform could cock/tilt IF you were to stand at other, outer edge of the platform(farthest from the bucket) even with the chains at both ends. You may already know this, but it deserves repeating.
Wedge
Wedge40,:)
Yes, I got detailed photos.:D I added a 4x4 attached with 1/2 inch lag bolts to the back slope of the bucket and blocked from there using 2x4s as spacers and stops for the blocking. One 2x8 and two 2x6s are jammed up under the bucket lip, along with a 4x4 knotch cut to fit good, attached to the ball mount on the receiver tube with a 1/2 inch lag bolts. Luke and I both jumped on the end of it and nothing happened. It creeks and groans only when I first pick it up off of the ground. It didn't creek or groan during the jumping. We had the tractor front end bouncing up and down like a low rider! :D The frame is 3 eight foot 2x6s under 3/4 inch.
hugs, Brandi
Catman,
It wouldn't work at all without the blocking. Thanks for the input.
hugs, Brandi
/ Wooded loader platform #18
Good job on the blocking.:)
/ Wooded loader platform #19
WAY off topic for this post, but have you considered moving that low spot/ditch closer to the fence? That would give you a more stable and flat area to drive around your barn, plus keep that water away from your hay and equipment. I don't think the goats would mind too much and it would be short work with the hoe and loader.
David from jax
/ Wooded loader platform #20
Ma'am,
As someone who has worked and hung from great heights with nothing but air underneath, I would recommend a safety harness.
A length of static kernmantle rope attached to a substantial anchor (maybe from the other side of the barn and up over the roof, with folded tarps at sharp edges to protect the rope) and an ascender/carabiner combination attaching you (in your harness) to the rope.
You would clip in (on-rope) to this whenever you go up on the platform, and adjust your position on the rope with the ascender. Unhook (off-rope) when leaving the platform.
