why use roof trusses?
/ why use roof trusses? #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I'm still pondering how to go about building a pole barn with a higher than normal ceiling, 14 feet. I was thinking I would just build the walls 14 feet high, then use roof trusses. But, now I'm thinking that maybe it would be better to not use trusses and just use a center beam with rafters to eliminate the bottom part of the truss (is this called post and beam? I'm not sure of the terminology). That would allow me to use shorter walls and still get the height I need.
So, does this make sense? Why do people use trusses in the first place? I'm learning as I go here. I don't want to hire it done, partly because I can't afford it and partly because I won't learn to do thing for myself unless I "just do it!".
/ why use roof trusses? #2
Danny,
The big question is how large of building do you want. Roof trusses are normally used so that you can span a larger area than you would be able to with conventional lumber sizes. Let us know how wide and long you want the barn to be and we can give you an idea if it is practical with out trusses.
MarkV
MarkV - I'm planning to build a 22 foot wide by 24 foot long building.
/ why use roof trusses? #4
Trusses are less expensive than plain timbers when used to span longer distances. They also function as collar ties to prevent the exterior walls from bowing out. You could use dimensional lumber for rafters, but collar ties (ties parallel to the floor that restrian the exterior walls from bulging outwards) would still be required. There are many types of trusses beyond the simple truss. Some, like a scissors trust, allow for greater headroom in the building. Others, like attic trusses, allow for load bearing floor surfaces upstairs. Trusses take less time to install than dimensional lumber rafters
/ why use roof trusses? #5
<font color=blue>to eliminate the bottom part of the truss</font color=blue>
you can't do that ---- picture your rafters leaning against the center beam and braced on the top plate. without joists running from wall to wall to keep them tied in, your walls will be pushed out of plumb by the weight of the roof pushing down and out on the walls. A few years ago I helped a friend put up a garage with 10' walls - when he priced the difference between stick building the trusses or buying them - the trusses were each $10 more - not enough to warrant the time and trouble doing it ourselves. And the manufactured ones I'm sure were better than we coulda built.
mike
/ why use roof trusses? #6
Here's a <A target="_blank" HREF=http://www.cheshirerooftrusses.co.uk/roof_trusses.html>link</A> to a page with various types of trusses pictured. Surely not every kind, and you probably wouldn't want to get them from Cheshire./w3tcompact/icons/wink.gif
/ why use roof trusses? #7
Danny,
A roof that wide can easily be build with convention sized lumber. Your rafters would be cut out of 14’ or 16’ boards depending on the pitch and the size of the eaves you want. For a roof rated at 30 psf live load you could use 2x6 southern yellow pine on 16” centers or 2x8 on 24” centers.
I think where you will run into a problem is the length of the building. To build a roof with out ceiling joists (the crosspiece from the top of one wall to the top of the opposite wall) or collar ties (like a ceiling joist but attached above the top of the wall to the rafter) you need a structural ridge beam. A beam 24’ long will be hard to work with and expensive. It would have to be an engineered beam (laminated lumber) which are built to a size their computer figures out based on you building plans and area snow loads. You could get around this but it would require and interior post to break the 24’ span to shorter lengths and that is what most are trying to avoid in a barn.
That is a rather simplified explanation so if I was not clear enough for you let me know and I will try again./w3tcompact/icons/eyes.gif I think as you research farther you will find that trusses will be the most economical way to build what you want. There are also trusses made that the bottom cord (carpenter word for the piece across the bottom) rises to a high point in the center (like the roof does) if that would help meet your height needs.
MarkV
/ why use roof trusses? #8
Danny, I built my shop using Scissor trusses and have 8' walls and have a hieght of over 12' in the center. And have an 8' overhead door to get in. My shop is 24' x26'. I don't know if that will work for you or not, but its an idea.
/ why use roof trusses? #9
Hi Danny,
You have a couple of choices here. For maximum headroom, use a structural ridge beam with a very significant post at each end. The beam would either be a glulam or a steel wide flange section.
A much simplier solution would be to use scissors style trusses. The bottom chord pitches up to the ridge at approximately 1/2 the rate of the top chord. By all means, use a truss plant to engineer and fabricate the trusses. Member sizes, connections, lateral bracing, loading, etc. should not be guessed at by someone with only good intentions as qualifications. Your building should be safe and reliable. I hope you can afford to build your building right.
Good luck
Yooper Dave
Thanks for all the info. Everything you folks said makes sense. The scissors truss sounds good, but only gives me the height I need in the center. I need the 14’ height to start about 3’ in from the edge of the wall (it’s for clearance for a car lift, which will be used to lift full size trucks and tractors). Actually 13’ would be probably be enough. My suburban and pickup are both over 6’ high counting the roof rack and I want to be able to lift it so the bottom is 6’ off the ground so I can walk under it. My Boomer is not quite as tall, but there’s always a chance I could get a bigger tractor someday, or my neighbor might want to use the lift for his tractor, which is a bigger tractor. MarkV, you’re right, I don’t want any center post in the way. The engineered beam sounds too expensive.
I started out planning to build 14’ high walls, but when I went to talk to the building codes guy he said I can’t have wall that high with having them engineered, which sounds expensive to me. He was going to check on whether 12’ walls were OK and get back to me, but hasn’t yet.
So, any recommendations on how to proceed without getting into too much money? Or, is this something that can’t be done without spending a lot of money on a engineered design? Thanks.
/ why use roof trusses? #11
If you talk to the truss company directly I'd bet they can make a modified scissors truss to give you the rise/run you need for the lower chords of the truss. Generally they just plot it out on a computer and the jigs will allow assembly of different trusses to specs.
BillG49 - The "Raised Tie Truss" in your link might work. I'll see if the local lumber places can get those.
/ why use roof trusses? #13
Danny,
Think about builidng it pole barn style. They have a different set of rules than conventional building. You should easily be able to build 14' walls without any problem. Go 8' on centers for your trusses and you will be set. You can finish it off inside with white steel, ALOT cheaper than drywall, and it will look very nice. That's how I did mine. If you want pics let me know.
cowboydoc - That was a pole barn style that I asked the building codes folks about. They said a wall that high would have to be "engineered" by a certified professional or be an engineered kit. Something about special bracing and that the poles would have to be deeper and/or reinforced in concrete or something like that. I called them this morning to find out more details, but both inspectors are out in the field today, so I'll have to try again tomorrow.
/ why use roof trusses? #15
Wow that surprises me. Are you building this from scratch then or buying one of the kits from like Menards or somewhere?
/ why use roof trusses? #16
The codes concerning wall height are probably concerned with the "moment" wind/snow loads would produce at the top and base of the foundation/ roof joint due to lack of adaquate lateral support. The building could buckle sideways under the right conditions if the wall cannot resist the lateral forces.
Egon
I was originally planning on doing it from scratch by getting a good book and talking to people who have done it. I was thinking it would not be that complicated, just follow the codes for how deep the poles need to go, spacing, etc. But, now I'm looking for a kit or plans for one that is 14' high. So far I've only checked at Lowes, and they don't sell kits or plans. I'll try Home Depot, Menards, and some lumber yards next. Unfortunately, there's not much in Columbus Indiana, just Lowes and one other small lumberyard. Lowes ran 2 other lumberyards and an appliance store out of business!
/ why use roof trusses? #18
Danny,
We had to have plans certified by an engineer for a fire station that our local Fire District was building. We went to the local pole barn building outfit and told them what size we wanted our building. We bought the materials from them and got a set of plans stamped with the seal from the engineer . Didn't cost any extra and we were in compliance with all the rules
/ why use roof trusses? #19
Danny,
Like Cowboydoc I am surprised they are giving you a hard time about having 14’ walls on a pole barn. Farm equipment sheds are made with high ceiling all the time in the Midwest. Maybe try the ag extension office and see if they have any information.
As someone else said it should not be very expensive to get an engineer to stamp the plans. It may require some cross bracing for wind loads but not a big deal.
MarkV
Well, I just called the county extension office and they referred me back to the building codes office that I was talking to before. It sounds like I live in an area that's just over regulated.
204158 (A57193)
204158 (A57193)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2011 Chevrolet Express 2500 Cargo Van (A59230)
2011 Chevrolet...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2014 FREIGHTLINER CASCADIA DAY CAB (A59905)
2014 FREIGHTLINER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
