MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,697
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
We took in a used 3316 turbo last week with 25.9 hours! It had been garaged and was perfect, but it also sold the first day. They come up like that occasionally, but not often and unless you find one local to you, you simply cannot get to it before it is sold.
At your elevation, and with the added weight of a backhoe I'd also recommend the 3616. 8 more HP. But the 3016 will do the job and has adequate HP even at elevation to run the pump fine, meaning the backhoe would dig perfectly and the loader would lift fine. But pushing a pile of dirt with the bucket or other heavy ground engaging tasks will require low range, slow speed and some patience with a 3016. Still incredibly faster than a shovel and wheelbarrow.....![]()
Dave, any used 35 series machines on hand?
Honestly, with the pictures that the OP has posted, a 5035, or now a 3550 would be the absolute minimum machine to use IMO. But if you can't afford it, you can't afford it and you have to get by the best way you can. I still think used would be his best alternative, and not a 16 series machine at all, but a 35 series at the minimum.
But that's just me.
