whole house fan
/ whole house fan #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i "may" have asked this before, if so, i do not remember the answer: sorry if i am repeating myself: why couldn't a heat/ac blower fan, be used as a whole house fan? put it in the attic, with an opening about the size of the return air: an exhaust it to the outside: i have several of these things, an use them occasionally to set up and circulate the air in my garage when i am working in there, an they really do a heck of a job: i put one under my house several years ago, when it got a little damp under there, to dry it out: till i could locate an repair the place water was coming in: an again it seemed to work great: anyone ever try one as a whole house fan??
heehaw
/ whole house fan #2
never tried it, but i cant see why it wouldn't work. A fan is a fan. The ac motor should be plenty quiet and is designed to circulate air.
would probably need some kind of auto damper though to close shaft when not in use.
/ whole house fan
i was thinking, build a box in the attic for the fan, an put a spring loaded damper in the exhaust, so when i turn the fan on, it blows it open, an shuts when the fan is turned off..all i would do is open about 5 windows in the house a couple inches each, to get the air to circulate thru the house, an i just cannot see how this wouldn't work...
heehaw
/ whole house fan #4
i use to have a couple of these old A/C plenum blowers in my shop and they really do great for blowing air, however all would do is blow the same air around, I then got a 48" attic fan and mounted it up high in the wall of my shop I can now open one of the doors on the far side from the fan and in a mater of minutes have the hot air exhaust to the outside,.............
I'm sure what you are suggesting will work as well, although you might consider building a plenum onto the inlet side of the blower and run a trunk of 15" duct to a Y-reducer stepping down to 2x10 and split into 2 trunks leading to rooms on each end of your home, remember these are designed to pull from multiple of returns throughout the house,
13' ORLANDO CLIPPER FIBERGLASS JOHN BOAT (A64281)
13' ORLANDO...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
429835 (A61166)
429835 (A61166)
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
UNUSED SDLANCH SDLC2533FT 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
