jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
</font><font color="blue" class="small">( so, i could buy a couple of 8ns, (at what point did theymake a live PTO? maybe they didn't) )</font>
I would not personally go back as far as an 8N if I wanted to do something more that mow and a few other chores. I'd probably suggest a Ford 600 series or later. They had live hydraulics, but no live PTO. Actually, I'm not sure when the live PTO became an option, but it relied on a two-stage clutch. My guess is somewhere in the early '60s. The reason I suggested old Fords is that all their body parts are essentially the same for many years. If you have a hood off a 800 series tractor, it should fit a 600 series. The same goes for fenders. Many of the 3PH lift components and front end components are also the same. As Farmwithjunk suggested, the industrial models are also built like beasts. I had a '64 model industrial tractor with a cast iron grill. It wasn't interchangeable with other Fords with sheet metal, but it was so heavy, you would never damage it without being run over by a train. /forums/images/graemlins/wink.gif
I don't know a lot about other older tractors. Maybe older Deeres have interchangeable parts. I just picked Ford because I'm pretty sure they are available in numbers and a non-running old Ford with good sheetmetal and other parts can be had for around $1,000 if you find one. Many of the '60s model Fords even had power steering, but FWA was not common until the '70s when Kubota started importing their 4wd compacts.
BTW: I like my modern tractor and it's conveniences. I think $20,000 in today's dollars is comparable to $2,000 in early '60s dollars. In forty years our prices will look like bargains. I just use my tractor and try to not abuse it. Other than a couple of minor bumps and a lot of tree limb scratches, my tractors plastic and fiberglass are performing well. /forums/images/graemlins/cool.gif
