Which Gooseneck Trailer?
/ Which Gooseneck Trailer? #81
:thumbsup:
/ Which Gooseneck Trailer? #84
Do they weigh 1200 lb per roll like most? Scary!
Nice load of hay! What is a torque tube?
A torque tube is a 6"or 8" piece of pipe that is welded under the deck of the trailer between the frame members which is supposed to keep the trailer from flexing or twisting when loaded heavy to one side, I had heard a lot of different things about it, but was told by several people that with a pierced frame that you really didn't need it unless you went with a really long trailer, I tried it the other day in the field and loaded one side all the way prior to loading the other and nothing tilted budged of flexed, I won't make it a habit now I will load it evenly as I go about loading the trailer, but I had to try it.:D
/ Which Gooseneck Trailer? #87
At least 24k behind a 3/4 ton truck. Scary.
It wasn't scary at all, I live out in the country and my hayfield is about 1/4 mile from the barn, I'm not pulling it in heavy traffic.
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
96"X18' TRI-AXLE TRAILER (A64280)
96"X18' TRI-AXLE...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
JLG Aerial Lift Service and Maintenance Manuals (A63117)
JLG Aerial Lift...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61573)
2013 Mack CXU613...
2018 International LT Automatic Day Cab (A62613)
2018 International...
