When is a Grapple a Tree Shear?
/ When is a Grapple a Tree Shear? #121
I do like how the "teeth" overlap - I can see where there could be some advantages to that!
Thanks for sharing. I alway enjoy looking at all the photos and seeing what people are doing with their machines.
/ When is a Grapple a Tree Shear? #122
WOW you children amaze me ! XFAX Can take pictures , post them , and obviously works very hard . What works for him , works for him ! Richard , 4750 , dt 86, you need to find someone else to pick on . I AM RIGHT HERE .
I didn't know we were "picking" on anyone. I don't think Xfaxman or anyone else feels that way. You are the one acting childish and called names. I have taken some flack before ( ok not 9 pages worth), and I didn't feel like anyone was picking on me. There are full on knock down drag outs that go on here all the time. The First thing that comes to mind would be anything that involves drones and the single lid VS duel lid grapple debate.
/ When is a Grapple a Tree Shear? #123
The limbinator?
That's it!
Basically take the limbinator, but mount the saw to the edge of the bucket (so it isn't sticking up in the air) and have it function like it would on a firewood processor, where when you open the flow to the hydrualic motor, it spins up the chain, and then pivots the bar down, cutting the log as it goes, then when you shut flow off, it returns back up.
SO, pretty much a combination of the Limbinator and a firewood processor bar. Sounds expensive. :D
/ When is a Grapple a Tree Shear? #124
Easy dude.
I ribbed faxman for doing things differently than myself, which was intended as good old fashion funnin. I hope he knew that. If we all did things the same it'd be a pretty boring world.
The marketers for the gorilla grapple pulled a fast one. They used the number for cylinder force for a 4" cylinder at 3000 pounds and indicated that this is the force at the ends of the tines. However, based on the dimensions you shared, the force at the end of the tines is on average about 1/5th of the cylinder force, or about 7500 pounds. The force would vary through the the arc as the cylinder angle changes.
I think that's a common marketing practice. To get the cylinder force at the ends of the tines the cylinder stroke would have to be the same length as their travel distance?? At least I think that's right??
Well I just heard back from Sidney Mfg., gladehound is right, it is 7204 pounds.
All I know is, it is strong enough to do whatever I have needed it to do. :thumbsup:
Had to be careful not to crush the concrete, when picking it up.
Had to be careful not to break this one, so I didn't close the tines down tight on it.
/ When is a Grapple a Tree Shear? #126
What is that little dump machine - looks neat
/ When is a Grapple a Tree Shear? #128
How many scoops does it take to fill it.
/ When is a Grapple a Tree Shear? #130
Does the V417 have the traction to completely fill the bucket in dry dirt?
/ When is a Grapple a Tree Shear? #131
That is pretty cool - bet it is really handy for moving a lot of dirt
Yep, note the bucket teeth marks in the hard shiny red clay.
Yep, brush and cedar trees also. :thumbsup:
/ When is a Grapple a Tree Shear? #134
Yep, note the bucket teeth marks in the hard shiny red clay. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=454547"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=454548"/>
Clay is still easy digging compared to the dirt we have. How tall is that dump truck. My tractor can just barely load a 1 Ton dump, and yours looks taller.
From a brochure: 1630 mm (64.1732283 inches) to the front lip.
It warmed up to over 40 degrees, so I went out and measured it: front is 64", side is 69".
The V417 is 6.5' to the top of the cab.
/ When is a Grapple a Tree Shear? #136
1630 mm (64.1732283 inches) to the front lip. The V417 is 6.5' to the top of the cab.
That's not as tall as it looks. The average cut could load that without any trouble.
/ When is a Grapple a Tree Shear? #137
Xfaxman
Do you want to come over to my house and play? You could bring your toys and we could have all kinds of fun!!:laughing: Ed
/ When is a Grapple a Tree Shear? #138
Xfaxman Do you want to come over to my house and play? You could bring your toys and we could have all kinds of fun!!:laughing: Ed
It would be a long haul.
Used my test gauge to check the pressure at the aux connector on the boom.
Showed 3200 psi
Put the grapple on and clamped the center tines on a chunk of 4" thick concrete.
Squeezed and the relief opened, but no crush. :confused:
Tried a different piece, couldn't crush it, but with some curl down, it broke.
Fortunately I don't need to crush concrete with it. :thumbsup:
2020 Chevrolet 5500HD 4x4 Reading Service Truck (A64556)
2020 Chevrolet...
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
7000bu Grain Bin (A66408)
7000bu Grain Bin...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
