When is a Grapple a Tree Shear?
/ When is a Grapple a Tree Shear? #101
The marketers for the gorilla grapple pulled a fast one. They used the number for cylinder force for a 4" cylinder at 3000 pounds and indicated that this is the force at the ends of the tines. However, based on the dimensions you shared, the force at the end of the tines is on average about 1/5th of the cylinder force, or about 7500 pounds. The force would vary through the the arc as the cylinder angle changes.
I think that's a common marketing practice. To get the cylinder force at the ends of the tines the cylinder stroke would have to be the same length as their travel distance?? At least I think that's right??
/ When is a Grapple a Tree Shear? #102
XFax started this thread to show off his equipment and show his pictures. I think it's pretty disrespectful to come right out and start giving him a hard time for posting pictures online of his equipment. If you don't want to look at them, no one is forcing you to open his thread.
Personally, I think if you post too many non relevant pictures/info in someone else's thread, then there is justification to call someone out on it within reason, however, if you guys have a problem with him starting his own thread and posting pics, then I think that is quite disrespectful. This is just my own opinion and take that for what it's worth.
If you guys aren't aware, there is an "ignore" option that will block you from seeing all of someones posts.
And what has been your contribution to this thread?? ;)
/ When is a Grapple a Tree Shear? #103
Derek, I'm assuming they are just as prolific in VA as they are in MO???? :(
Probably so, you can count on them taking over fence rows and rocky areas if left unattended.
/ When is a Grapple a Tree Shear? #104
WOW you children amaze me ! XFAX Can take pictures , post them , and obviously works very hard . What works for him , works for him ! Richard , 4750 , dt 86, you need to find someone else to pick on . I AM RIGHT HERE .
/ When is a Grapple a Tree Shear? #105
And by the way undrszd is that your grader you keep showing off ? No, it is the township machine . Really did enjoy your posts till lately .
The reason that I started this thread was because I had never seen any pictures of a grapple shearing a tree trunk.
This happened unplanned, I was headed up the trail to extend the other end further up the deep creek.
I came to the fallen dead tree in the first picture, knew it would be difficult to get to it from either side to pull it out of the way. Then I remembered the outlandish crushing power claims by the manufacturer and decided to see what would happen if I tried to crush it with one tine. So I posted the pictures. :shocked:
/ When is a Grapple a Tree Shear? #107
I'm glad you did Dennis. By the way, reading through this thread and looking at the photos gave me an idea. I wonder how difficult it would be to rig up a hydraulic chainsaw on the edge of my grapple.
I'm picturing something like a wood processor bar/chain setup, that would be able to mount/dismount to the right edge of the grapple frame, then when clearing trees, knock the tree over, grab it in the grapple, activate the chainsaw using a rear remote, cutting the tree into a section as wide as the grapple, then repeat.
Seems it would quickly cut long trees into manageable sections to carry through the woods. I know you wouldn't have much use for it but in the thick New England woods I live in it could be a pretty cool addition to the grapple!
/ When is a Grapple a Tree Shear? #108
Kevin, I didn't know I was picking on anyone. If Xfaxman thought I was picking on him he would defend himself. Him and I have had several debates about things. I don't take it personal. I'm pretty sure he doesn't. If he does all he has to do is say so and I will immediately apologize. Actually I think I already have apologized to him in this thread.
YOU ARE RIGHT ABOUT WHAT???
/ When is a Grapple a Tree Shear? #109
I'm surprised you are lowering yourself to calling me names and accusing me of showing off. Not sure what that is all about.
Now you are being personal in your comments. I got it.
I have seen something like that on a bucket, maybe someone will remember it.
/ When is a Grapple a Tree Shear? #112
Good contribution. Complex but effective if set up right.
I took it to mean he was RIGHT THERE for you to pick on him. :)
Yep, I don't take it personal.
/ When is a Grapple a Tree Shear? #114
Oh, I get it now. I'm kinda slow. :)
/ When is a Grapple a Tree Shear? #116
I don't really see any shear incorporated into the grapple, although such would be very usefull at times. I pick up thirty or forty foot long trees and then have no place to go, because the existing trees are too close together. Many times I just let them break off, but this is hard on everything and defeats the purpose of the excercise.
/ When is a Grapple a Tree Shear? #117
Yep, I struggle with that as well. And I hate to drag a log out of the timber. Fills the bark with dirt which dulls the crap out of the chainsaw. So, if it's simply debris I let them break off and then go around and gather up the crumbs. If it's good firewood I end up blocking it in the timber and then carrying it to the split pile. Adds another function to the process.
I don't really see any shear incorporated into the grapple, although such would be very usefull at times. ----------------------
It is not designed to be a shear, I just used it as a shear.
Look at these shears, note how one blade slides past the other:
Look at the grapple, note how the top tine slides past the lower tine:
That is how it sheared the trunk. :thumbsup:
/ When is a Grapple a Tree Shear? #119
That first shear. Do the straps go around ones ankles? Probably good for light brush only.
Still don't really understand your other picture. So you didn't cut off a log, you kind of shredded a stump if I understand correctly using the inter-twining teeth of the grapple.
The first shear is held in your hand.
To understand the other pictures you have to click "First" at the top or bottom of this page and read the first post.
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
