Wheelbarrow tires going flat
/ Wheelbarrow tires going flat #41
Have you sprayed tubes with Flex Seal ? Seems like the new rage.
No, I am a retro-grouch roadie who patches my flatted tubes with rubber cement and permanent patches. Tubeless bicycle tires apparently require at least 2 windings of special rim strip tape to prevent air escaping through spoke holes and also require a shot of Slime or similar to be distributed over the inside of the tire to seal the bead and offer the hope of self-seal on chance minor punctures. Changing a "Slimed" tire is messy. Flex Seal may be the new rage to compensate for thin, permeable tubes.
/ Wheelbarrow tires going flat #42
Small tires with small air volume are the worst. I'm 76 and have been fighting them my lifetime. I put up with it. But overall tire things are better than in the past. My last 3 cars have not had spares - and no flats. I have continual flats with one rarely used tractor, my only old one, made in America tire and assume the tube is also made in America. Have a small air compressor to air it up any day I want to use the tractor. I learned to live with leaky tube type tires, especially small ones. Solids if you don't want flats.
/ Wheelbarrow tires going flat #43
I'm kind of giving up on small air tires and going to solid where possible. I've done a retrofit on one wheelbarrow and getting ready to do it on another.
Side question .... Anybody using the dual wheeled ones? They look like they'd handle more load, but not corner as well.
I use one and it handles well
/ Wheelbarrow tires going flat #44
since your in OZ , I suspect an awnry Kuokka is huffing the air from your wheel barrow as you sleep
/ Wheelbarrow tires going flat #45
Why is it that small wheels with inner tubes keep going flat?
One of our wheelbarrows with a 13" wheel, with inner tube, just won't hold pressure. I've removed the tube, inflated it, and it shows no leaks. The valve does not appear to leak. But after re-assembly and inflating to 30 psi, next morning -- flat!
What's the go here?
I bought a 13" trailer tire, fit the wheel fine, holds air and is wider, flat at the tread, rolls better.
/ Wheelbarrow tires going flat #46
Mine was a hand truck. Finally took it to my favorite garageman to fix, and he gave the same advice: get solid tires. I bought a Milwaukee hand truck from Amazon in 2013 for $69.97, and those tires still haven't lost a pound of pressure. Amazon is now out of stock, but Walmart.com has it for $97.67.
(Inflation? What inflation? It was transitory!)
(The one thing I learned in math was the Rule of 72. Divide 72 by the inflation rate, and you have the number of before when the US dollar will lose half its value.)
/ Wheelbarrow tires going flat #47
I suggest your 'leak Detection' method failed. Inflate the tube and totally immerse it in a big tub.
You may find a tiny pinhole that you missed before. Double check the valve stem area and install a new valve core. I have heard that Chinesium Tires cannot be plugged. Bamboo and glue or something.
I personally don't own a Mexican Backhoe.
/ Wheelbarrow tires going flat #48
Re: The water test. Lately I have experienced several slow leaks with the tires going soft overnight or over a couple of days. Instead of the stream of bubbles released through a thorn hole or similar puncture, a bubble slowly forms on the surface of the tube and is released over one or two seconds. Often when one immerses a tube in a bucket of water, some air is trapped or adheres to the tube to be released later. Furthermore, if the tube is folded or buckled to fit in the bucket the sides of the tube pressing against each other may stop the slow leak As a result, a thorough water test is more laborious and time consuming than simply dunking the tube. Large water tubs or troughs may help.
/ Wheelbarrow tires going flat #49
I bought a bottle of tire and tube sealant from lowes. Tires have stayed inflated now for 6 months
/ Wheelbarrow tires going flat #50
It seems 2 wheels are the only kind they sell 'round here. I personally don't care for them, the extra wheel seem to always find something to catch on. Another problem I have (at least with the ones I find locally) is with the way they mount them up front. I swear every company must have 4 foot employees. They put the wheels so far toward the bucket that when I pick up to move the front end digs into the earth. I've literally moved the axle assembly on four different brand two wheel wheelbarrows at least 4 inches and from the center of the frame to the bottom to keep the front of the frame from digging in. I'm only 6'1" so I can't imagine what would happen to others that are taller (I've got the axel as far as it will go - guess you'd just have to get larger tires). I've fixed them all so they do work, but I'm not so sure there is that much difference between 1 & 2 wheels.
/ Wheelbarrow tires going flat #51
Dual wheel is mandatory on hills and wont tip over with an uneven load. Cornering??? It's not a motorcycle. Love mine.
/ Wheelbarrow tires going flat #52
For your small aired tire application, fill it with expanding foam like great stuff crack and crevice. Done
/ Wheelbarrow tires going flat #53
Tire slime works pretty good for tube or tubeless small tires in my experiences.
UPDATE:
I bought a new tube. Installed it, pumped a little air in to seat everything, and all good, so clipped the filler on to the valve stem, held the trigger until the gauge registered 30 psi, then released the trigger.
What happened next was all very quick. I heard a faint hissing, looked at the gauge again and this time it registered 40 psi and rising and then in the blink of an eye ----- BANG!
Turns out the plunger in the handle of the inflator gizmo wasn't shutting off when the trigger was released, and the air coming from my compressor soon (VERY soon) found the "Do not exceed" pressure! It all happened so fast I didn't even have time to release the clip which held the business end of the delivery hose onto the valve fitting.
The wheelbarrow is now sporting a shiny new solid tire, and some lube on the rubber seals and o-rings in the inflator gizmo solved that problem.
So if you have any tires which need blowing up, I'm your man!
/ Wheelbarrow tires going flat #55
They are so nice and can be used with one hand. Very stable but not usable sideway on a slope. I have both.
/ Wheelbarrow tires going flat #56
/ Wheelbarrow tires going flat #57
This is my four wheel version made from parts from a similar wheelbarrow that had a broken tub. The rear wheels track the front. The "legs" bolted onto the handles upside down allow me to push it without bending over. It's a bit heavy to dump if I have dirt or stone in it but for most loads of horse manure it's doable. Unless I have some heavy wet muck in it, I can push down on the regular handles and spin it on the rear wheels. The tires with tubes are over 20 years old so I have to air them up now and then.
I made this up after trying my friend's TSC model with ~8 inch rear wheels. Being tall, bending over to push it by the handles did not work for me.
/ Wheelbarrow tires going flat #58
That blown tire reminds me of my "city boy" friend. Last time I moved, I kept my horses at the place I had sold for a time. I was airing up my wheel barrow tires when my friend asked to use my compressor on his four wheeled cart with the wire sides. Turned out that he did not know how to use my inflator which was one of those that you let off now and then and the gauge pops out. I heard a loud bang! A bit ruffled, he stopped and then another tire blew. He headed for the house. I could not imagine someone not knowing how to air up a tire else I would have helped him.
/ Wheelbarrow tires going flat #59
I have had a dual wheel, foam filled (can't go flat) tires wheelbarrow for several years now and love it! With my bad back, one off kilter tilt with me trying to prevent the spill can shut me down for several days. With the dual wheels I don't have this problem. The barrow itself is plastic and the when the handles went bad I replaced them with metal handles bought online in a kit from Menards. Very pleased and would not go back to single wheel barrows at all.
/ Wheelbarrow tires going flat #60
I'd be worried about how that handled while I'm going fast around a curve.
2024 HAMM HTC-15 TRENCH COMPACTOR (A64278)
2024 HAMM HTC-15...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2023 Chevrolet Tahoe SUV (A64557)
2023 Chevrolet...
