Well Water Filtering
/ Well Water Filtering #11
heehaw,
Do you have any info on the manufacturer/makes/models of your equipment. I will be building in a few years and will have supplied well water and will need a filtering system. I would like to look into this type, it seems to be the least chemical based and lowest maintenance that I have heard about. I would prefer not to use chemicals if I can.
Thanks,
/ Well Water Filtering #12
we have a local company that makes the fiberglass tanks, but they also use concrete tanks, i think they are actually the vaults that are placed over caskets?? just turned up the other way..i prefer the fiberglass because i could move it where i wanted it...i have seen some folks use old bathtubs...even 500gal concrete tanks, buried in the ground..all you need is a tank,preferably one with 2 sections; then you get the pipe that goes in the bottom, from a plumbing supply, i wish i could remember what you call it, but it has lots of long, narrow slits in the pipe...anyway, lay as much of that pipe as possible in the bottom of the tank, with a pipe coming from that slotted pipe to the top, to hook the pump to...then put in 12-24 inches of washed rock/gravel, then put sand on top of that..i use sandblast sand, because its readily available, if you can get it, the medium grit is good, the local company quit handling anything except the fine grit, so i have to clean the top more often now. another way to do this, without using the slotted pipe in the bottom, is with a tank, and then put one of those plastic barrels in the middle of the tank, cut some one inch holes in the sides, near the bottom of the barrel, then put bigger washed rock, ten smaller rock, then sand...run your water onto the sand, and then pump it from the tank..maybe turn a 5gal plastic bucket upside down above the barrel, and spray the well water into that bucket, to aireate the water, that allows the iron to be filtered out better...is all this clear as mud?? oh yes, you need a float valve in the tank, to cut the well water off when the tank is full...this really works great...if you have a place to get sterilized sand?? if there is any such thing..that would probably work better..
heehaw
/ Well Water Filtering #13
heehaw:
How do you backwash the filter.
From the description it could work on gravity feed if the tanks are set at the right level.
Coal or charcoal can also be used in this type of filter. Activated charcoal if chlorine is used.
They can also be built to operate under pressure and backwash when differential pressure reaches a predetermined value set for the filter.
Egon
/ Well Water Filtering #14
no back wash on this type of filter, you just remove and replace the top couple inches of sand occasionally, how often depends on how much iron is in the water. then every 2-3 years, some folks clean the whole thing out and start over, but i've only done that once in the last 6 years, and i washed the gravel, soaked it in a barrel with a lot of chlorine, then used it again, but replaced all the sand. some folks here actually use 1000 gal concrete septic tanks to do the same thing, they have them buried, sticking up slightly to keep runoff water out, they also do it with the water going down thru the sand and gravel side of the tank, and then pump the filtered water from the other side..seems to work..
heehaw
/ Well Water Filtering #15
Agree with your thinking. Egon.
We're using gravity feed and have suitable fibreglass tank.
It would seem, if vertical feet from source is sufficient, that one could simply swith a valve on the the inflow feed to run from the bottom up to backflush....course if you did that you would be backflushing with unfiltered water.
/ Well Water Filtering #16
heehaw/Wasabi
As usuall I had trouble expressing myself. I was thinking along the lines of a municipal water treatment plant where gravity sand filters backwashed by filtered water are a common design.
Egon
/ Well Water Filtering #17
backflushing a pressurized filter is very common, the water softner has an automatic backflush, but to backflush a tank with no place for the flushed out crud to go wouldn't solve anything, and just contaminate the sand underneath. the iron stops up the sand, so the water won't soak thru to the pump lines, so just cleaning the top inch or so gets rid of the iron and keeps the water running.
heehaw
/ Well Water Filtering #18
Gravity sand filter:
There is an overflow line[trough at the top] to handle the backwash water and crud. The backwash pressure must be such that the sand is not carried over. They usually have a spyder pipe arrangement on the bottom to evenly distribute the the backflush water.
Egon
/ Well Water Filtering #19
When we bought our Central Ohio farm a year ago, it had a drilled well at least 60 years old with the pump, pressure tank and associated mechanics in a below-ground pit. From there, a 200-foot+ line went to the house, where it went through a 12-year-old Culligan water softener. Iron staining and flavor were the problem with the water output from the Culligan unit. To his credit, the local Culligan repairman said there was no reason to replace it. He tested the untreated water for iron, said it was within the capability of the softener, serviced it, advised the use of Iron Out, and that was it.
Except for the iron flavor and the iron content, which remained noticeable and unacceptable. I had previously tried "shocking" the well with chlorine, but after a couple of weeks of improvement, prior conditions returned.
The obvious solution was to install a sophisticated iron filter before the softener. But that required the pressure tank to be nearby, in the basement, and the well was too far away for that. Also, major changes would have required bringing the old well up to code by raising its mechanics to ground level.
It proved more cost-effective to have a new well drilled near the house, which we did. That water tested negative for bacteria but not surprisingly had a good slug of iron, like all the water in this area.
Once the new line was in the house, the driller hooked it first to a sediment filter which, to my surprise, hasn't had to do much work in spite of the sandy shale in which the new pump is sitting.
From there, it goes to the pressure tank, and then to a Provectr AF-10P, a two-tank system for removal of iron (and manganese and sulfur) from the water. First piece is a venturi/nozzle that oxygenates the water. That's said to convert dissolved into suspended solids that can be filtered out more easily. (It also requires good pressure, which is why this tyhpe of iron filtering system must be near the pressure tank.) Next, it goes to the aerator/precipitator tank, at the bottom of which are "plastic aeration orbs that become coated with contaminants that have been separated from the water through the oxidation process" and "which help solidify unoxidized contaminants," according to the brochure. From the bottom of that tank, the water, with a lot of what would otherwise be undissolved contaminants now in particulate form, goes to the filter tank, where a blend of media filters contaminants (most notably the physical particles produced by the oxidation process) and raises the pH of the filtered water.
The big question always: maintenance. This system backwashes automatically. The manual suggests checking the pH neutralizer portion of the media twice a year, and also gives instructions about putting chlorine through the system when it needs to be cleaned. The driller suggests simply inserting chlorine via the sediment filter housing.
The treated water from the iron filter goes to a two-tank, demand-regeneration water softener.
I had the driller put in a T fitting between the iron filter and the softener, so I will be able to tap off drinking water that will still have calcium and magnesium in it.
As far as I was able to tell from my research, this kind of system is as close to automatic and maintenance-free as they get. The downside: an iron filter of this sophistication costs virtually the same as a top-quality water softener; each is about $1000. But in addition to the convenience factor, it will greatly extend the life of the beads and mechanics in the softener, which no longer has to deal with high levels of iron and manganese and sulfur.
In our case, we saved a fair amount on labor by having it installed at the same time as the new well. Speaking of which, I would strongly recommend that a "hydrant" be installed there for less than $100. It's great for accessing untreated well water for gardening, watering, etc.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
