Well Pump Expansion Tank
   / Well Pump Expansion Tank #41
That is the pressure valve ( like a bike tube air valve. The cap pops off and if you look at the electric pressure switch the air pressure is set at 2 lbs less the the cutoff pressure. You can use a tire pressure gauge to check the pressure. If you believe that your water pressure is good at the sinks, then leave it alone.
UNUSED LANDHONOR LHR-PC90 HEAVY DUTY PLATE COMPACT (A51248)
UNUSED LANDHONOR...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
TRAILER CHASSIS (A51247)
TRAILER CHASSIS...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
