Well Pump Electrical Problem
/ Well Pump Electrical Problem #21
Pulling too many amps causes the overload to trip, not the breaker. Again, this is easy if you just use an ohm meter to check for a short.
Sorry guys, I can't give any more details about the pump or the wiring. They live an hour from me and I only get over there every few weeks.....and.....despite being a decent weekend-warrior mechanic and carpenter I am an idiot when it comes to electricity.
@workinonit , I live below Charlotte. They live in the middle of nowhere between Winnsboro and Newberry.
I think right now, if we (me and them) decide to try anything ourselves other than checking pump verses breaker specs, it will be to run a continuous (unspliced) above ground wire to the well head and see what happens.
/ Well Pump Electrical Problem #24
400ft sounds like voltage drop from too small of wire, or water shorting the wire splice.
/ Well Pump Electrical Problem #25
I've got a well, along with my depth and distance from the pump, probably close to 400'. I did a simple resistance reading across the coils and from the coils to ground. The readings i got were very close to the resistance specifications for the 1 hp pump has across the starting and running coils. With that i was pretty sure my pump and wiring was ok. Not absolutely sure, but if my reading had been very different from the specifications, i'd know there was a problem with the pump or the wiring. Turned out i had a problem in the "pumptek" module.
John Deere 700 H Dozer (A62679)
John Deere 700 H...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2005 MACK VISION (A67714)
2005 MACK VISION...
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
