Welding projects
/ Welding projects #1
Professor Marvel
Platinum Member
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Does anyone have websites that they recommend that might have small around the house welding projects? Could be functional or simply ornamental. I am looking for some projects to do so I can practice welding since my experience is minimal. I want to learn more before I weld something that requires a level of structural quality to be safe.
Thanks for ideas
/ Welding projects #3
Here are few projects I've done in the past. Maybe one or two will be of interest to you.;)
/ Welding projects
Thanks SA
I just ordered the book you recommended.
/ Welding projects #6
Just do something with what you have available. Even something simple like making a rack to hold your garden tools, a coat hook, hose holder, mailbox, yard art, something with horseshoes/nuts/bolts/washers/etc..... Just get creative.
/ Welding projects #7
You might want to look at youtube. Search on simple welding projects or some similar search phrase.
/ Welding projects #8
Here is a easy project to build. And handy as a pocket on a shirt. Will work on the front end loader, or the 3-point hitch.
/ Welding projects #9
That is what I do, and usually there is something broken around the house for me to fix.!
Since I have learned how to TIG (more or less :)) that has really opened up the amount of household things to fix.
/ Welding projects #10
Everybody can use a lumber rack for their pickup. This one was built with material out of my scrap pile. Just had to buy the paint.
/ Welding projects
Thanks for the direction. That should give me plenty to inspire me.
/ Welding projects #12
If you're anything like me (I wouldn't recommend that :rolleyes:) every project you do will cause you to think of at least two others, and just AFTER you paint the current project you WILL think of at least two modifications for that project :confused: ... Steve
/ Welding projects #13
Must be why none of mine get painted :D
/ Welding projects #14
Dave - naw, it's 'cause all the water where you live is probably too frozen to cause rust, so paint's not necessary :D ...Steve
/ Welding projects #16
If you build one of these first you will be better off than building one after having cut everything by hand for 25 years.
306736d1362610657-show-what-tool-you-made-img_20130306_163953_915-jpg
/ Welding projects #18
If you don't already have one, I would say a welder cart is the best first welding project.
... and shieldarc, I'm not sure a bridge crane is the thing to weld if you are looking for practice. :laughing:
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
Caterpillar Service Manual Reference Kit for Motor Graders, Wheel Type Tractors, and Equipment (A63117)
Caterpillar...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
