Welding BH frame
/ Welding BH frame #1
fcamillieri
Chester, NH
CK20HST
I'm having a hard time keeping the bolts tight. Has anyone welded the braces on their BH? I can't think of a reason not to. I imagine they are bolted for easier shipping.
Frank
/ Welding BH frame #2
Frank
Why not use some locktite?
/ Welding BH frame #3
I have not welded them but I had the same problem. I even twisted bolts in half trying to tighten them up. I would up getting really heavy grade bolts and used a MAJOR johnson bar with a pipe on it and loc-tite. No problems since.
/ Welding BH frame #4
Frank
I welded mine several years ago.
No problems since.
/ Welding BH frame #5
I second the idea of locktite, the stuff has worked well for me on other applications.
Joel
/ Welding BH frame #6
Frank
I welded mine in about a month ago as I could not keep them tight and I even used Lock Tight Extra Strengh and I finally took the welder to them and now they don't move and snap around like they did., It is a lot smoother on the machine too... why they bolt them on I do not know.
The Fox 1940
/ Welding BH frame
Thanks for the info. I think I'll weld it mainly because I'm lazy and it's the easy thing to do.
Frank
/ Welding BH frame #8
I DRILLED 3/16 HOLES THROUGH THE NUTS AND BOLTS AND USED COTTER PINES. I THOUGHT I WAS THE ONLY ONE THIS HAPPENED TO.:eek:
/ Welding BH frame #9
Would you need to cut the welds to remove the hoe? or is this a subframe that remains on the tractor and does not affect implement usage?
My hoe has frame that bolts to the tractor and then the hoe has a 4 point mount and comes off of the tractor with a lever, the frame that remains has no impact on implement usage.
I'm guessing they are bolted on because not every tractor comes with the sub-frame if you are not using a hoe?
Joel
/ Welding BH frame #10
The bolts attach the BH to the subframe. The subframe has no bolts attaching to the tractor.
/ Welding BH frame #11
I have welded several customers.
/ Welding BH frame #12
Rick, when you welded them how did the bead form on the skin? :D:D
/ Welding BH frame #13
OK then....you're talking about the frame section which is attached to the backhoe, which is then attached to the subframe?
/ Welding BH frame #15
I'm trying to understand, once welded can the backhoe still be easily removed from the tractor?
Joel
/ Welding BH frame #16
Yes. The frame bolts they are welding are on the portion that slips off when you pull the pins. Its the frame that slips under the tractor and engages the recievers located towards the front of the tractor and the reciever just under the power takeoff.
2011 MIDLAND  GOOSENECK SPOOL TRAILER (A68842)
2011 MIDLAND...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
32ft Flatbed Equipment Trailer (A64556)
32ft Flatbed...
1998 TRAILMASTER PUP FUEL TRAILER (A67714)
1998 TRAILMASTER...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
