Weld Lines on Buckets.......??????
/ Weld Lines on Buckets.......?????? #1
Frankdozer
Bridgton, Maine
1967 Case 580CK Backhoe / Loader
Most backhoe, bulldozer and tractors buckets have weld lines on them. Some are nice and evenly spaced, some are just eratic patterns. Being a welder myself, I know that these weld lines take some time to do. Just what do they do that for? Thanks, Frank
/ Weld Lines on Buckets.......?????? #2
Do a search on "hard facing" or "hard face welding"
/ Weld Lines on Buckets.......?????? #3
You don't need to hard face the entire side or area of a bucket you want to be wear resistant. Some welding rods will recommend a cross hatch pattern. some folks just do helter skelter. Those beads are for keeping your bucket from wearing through or getting thin.
/ Weld Lines on Buckets.......?????? #5
i saw a game of tic-tac-toe on a bucket once
/ Weld Lines on Buckets.......?????? #6
THe cross hatch will trap the materthats abrasive and hold it so the material its cutting is abraiding against it. Some is a built up dot pattern thats more for rock I think. Also a erring bone pattern is popular. Back in 2003 when the company i work for folded I went to welding for a sand pit. I had to weld up the buckets from the loader and excavator with the cross hatch. Talk about forever and a day of welding and then going over it again. One 5 yard bucket had over 250 pounds of rod built on it.
/ Weld Lines on Buckets.......?????? #7
Two subjects I've seen more knock down drag out fights over, is patterns for hard facing, and what angle to weld teeth on augers! :laughing:
/ Weld Lines on Buckets.......?????? #8
Could be some shops have "quality" standards and others just want the job done and not particularly interested in the prettiness.
RC
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2009 BETTER BUILT PH2322DT-E TRAILER (A66091)
2009 BETTER BUILT...
PORTA POTTY (A67714)
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2019 Autocar ACX...
