weld grinding tips needed
/ weld grinding tips needed #41
Ed,
been a long time since I've been in college...but I bought the book, 35 bucks and cheap shipping, like new.
and there will be a quiz...:D
many thanks
Drew
You won't regret it. I have two copies. One for the garage/workshop and one for, well, shall we say the toilet area. You never know when you are going to want to study up on welding!
Jim, thanks. I thought about what you said, and understand the 220 issue. If I weld a piece of half inch steel to something much larger and thicker,
do I need the extra power to get enough penetration? Make the right puddle?
Boy, knowing where to set that dial is a going to be an interesting learning curve. As long as I can dial a larger unit back, getting more capacity makes sense,
within reason, as I am buying tools "for life" now. Drew
I am laughing more than you can imagine because I was thinking exactly the same thing, my reading basket near the throne. Even wondered if we should start a new thread "what's in your bathroom?"...:D
Kinda rag earred the Northern Tools catalog, that old Tractorhouse is still interesting, all those neat sixties and seventies JD tractors. Want to restore one some day. So they can't go...sigh.
Something has to go...
/ weld grinding tips needed #44
I would not be too hard on the guy who did the welding .Sound's like he was told to do it cheap , fast and easy . Most of it looks good and will certainly hold . The ugly weld on the corner looks like layers of metal which means rust and is hard to clean up .He could have done a little touch up on it but he did'nt , who knows .
I agree. I know the guy who did it, he's done other welding for me, and he was given a rusted out POS to work with.
I guess if he finished it all beautifully I'd never learn how to weld. And he wasn't instructed to "go all the way around" though I kinda hoped he would...
I have cracks on my Honda powered Gravely wing mower, that deck is nowhere as bad as this one, but has a bunch of cracks in it. The prior owner had an apple orchard
and I think he got his apples down by ramming the wing mower into the trunk. Man that thing took some abuse and the PO really jury rigged it with home made materials.
I've got that one fixed and running nicely, just needs welding too. And I was smart enough to not paint it (yet) since I knew at some point those cracks really had to be fixed.
So I have two decks to weld, and paint. I do keep busy. :)
/ weld grinding tips needed #46
/ weld grinding tips needed #47
yes you need some power when you start welding bigger things to get good penetration. You can make lots of passes with a smaller welder if you joint prep really well. Keep in mind a lot of things you will want to weld are going to be a little rusty, and stick is your best bet if the joints arent perfectly clean and pretty. Also I think you are going to weld a lot outdoors on bigger machinery. Stick is the best bet their too. As the wind blows the shielding gas away from MIG.. Of course you can use gasless wire, Also known as Flux Core to get around that. Yes much easier to turn a Knob back, for less power, but you cannot turn one up for more past the design of the machine.
James K0UA
/ weld grinding tips needed #49
daugen I wish we lived closer so I could share some ideas and show you some of my collection. I also restore small tractors. What I have ranges from the 30's into the 70's. this pix is from a recent show I displayed at. I have a Lincoln 110v mig and an Everlast 220v dc welder that I just got last summer, with these I can do from the tin to the hitch I made to hook a 6 1/2' Meyers power angle.
/ weld grinding tips needed #50
DSCF0188 (Small).jpgdaugen sorry for the stupidity, I just can't post a pix.
good, I'm not crazy, I looked for one. The "advanced" features in that pic posting box can get challenging.
Make sure once you import the pic in from your pc that you check the box at the bottom. Then drag the pic to the bottom of the
box. THEN click Done. Forget any steps and you're going to grind your teeth. :)
/ weld grinding tips needed #52
daugen check post # 50 I finally got a pix to post
good job. Ok, from left to right, what are they: The one on the right looks like a prehistoric snow blower.
Is that IH Red?
Looks like great fun.
would appreciate some feedback on these Everlast products. The first one seems ideal for me. Both 110/220, TIG included, 160 amps and includes an optional foot pedal.
But the larger one has that special 6010 port. Is that relevant for me?
One thing I am sure of is I don't need shipbuilding or pipelining capability.
But if the 6010 rod is the one to use... but I didn't see that number mentioned by any of you,
so if it's for welding uranium or something just let me down easy...:D
new products:
PowerARC 160 STH
A brand new offering from Everlast, the PowerARC 160 has general purpose capability for almost all situations of repair and fabrication. Excellent for the hobbyist, farmer or professional welder.
PowerARC 200
Alongside its little brother, the portable PowerARC 200 has true commercial appeal. It can take on about any task whether pipelining, or ship building. E6010 electrodes are no problem for this unit, because of its special 6010 port that improves arc performance just for this rod. Purchase the optional TIG package and you will find a use for it about anywhere.
btw, I know we are off the grinding topic, but if you don't care, I don't....
/ weld grinding tips needed #55
This is a very tough decision to make!
On one hand the average guy can do anything with 6011 that he can do with 6010. I personally like Hobart's 335A 6011.
If you think you'll ever need Tig, the high frequency start, and foot pedal are the way to go. But there is nothing wrong with scratch start Tig either.
Those SA-200s in my signature are some of the best stick welders ever made. The Short Hood in my avatar was designed to run 6010. My PowerArc 200 will run 6010 every bit as nice as either one of my Short Hoods. The PowerArc 200 runs 7018 as good as any welder I've ever used.
You need to figure out what will work best for you. But hey I know people who have 3 and 4 welding machines.:laughing:
/ weld grinding tips needed #56
I would lean more to that Everlast PA200 or the Longivity Stickweld 250. Something with some current capacity. Ask ShieldArc again, and don't let him fool you about the "just starting out hobbyist crap" He has forgotten more about welding than most of us know.
It's interesting you suggest the PA200 or the Stickweld 250. It seems to me like the leading general-purpose machine in the Everlast line right now is the PA-160STH. 160 amps should be more than enough stick for any home repair that one is going to do, and the ability to expand into foot-pedal TIG lets the machine reach down into sheet metal and do other very fine work for which stick is ill-suited. Even if a person didn't want to invest in a gas cylinder, TIG torch, pedal, etc... right now, they could use the PA-160 as a fine stick machine until one day they decided to branch out. What's your thinking for going up to 200-250 amps and leaving TIG out?
/ weld grinding tips needed #57
daugen That one on far right is my 70's JD210, next to the left 50's suburbanite engine in the wheel, next on trailer is a David Bradley 50's 2 wheel tractor, next early 50's American Machinery 2 cycle engine, next is a 47 Montgomery Ward single wheel, behind the wind mill another Montgomery Ward walk behind 2 wheel. Everything there that is red, is IH red. As far as the Everlast welders, I have the Power Arc 200 and I like it, only did a few small things with it so far, but I have been using different rods and mostly experimenting and running beads. NOTE the colors I used on these tractors are original colors as close as I could tell from cleaning them. You mentioned a prehistoric snow blower: my 60 Gravely! The hood is off in this pix.
/ weld grinding tips needed #58
DSCF0160 (Small).jpgdaugen That one on far right is my 70's JD210, next to the left 50's suburbanite engine in the wheel, next on trailer is a David Bradley 50's 2 wheel tractor, next early 50's American Machinery 2 cycle engine, next is a 47 Montgomery Ward single wheel, behind the wind mill another Montgomery Ward walk behind 2 wheel. Everything there that is red, is IH red. As far as the Everlast welders, I have the Power Arc 200 and I like it, only did a few small things with it so far, but I have been using different rods and mostly experimenting and running beads. NOTE the colors I used on these tractors are original colors as close as I could tell from cleaning them. You mentioned a prehistoric snow blower: my 60 Gravely! The hood is off in this pix.
I have to power this off a 6500 watt gen with a 220 port, that puts out 27 amps,
so I don't think going over a 160 size is going to work for me.
My only objection to that unit is that it's made in China. Problem is the smaller Hobarts are too
if I'm not mistaken, you can't depend upon country of origin.
But the bottom line is the product is either built well or not, no matter where it's built.
It's all in the spec, the quality of mfg and quality control.
But if this unit costs say 450 and the same capability US made one costs a hundred bucks more,
I'll pay it. Problem is the cost is usually a lot more.
I've ruled out buying used, even something allegedly "such a deal" like this:
Lincoln Electric Arc Welder Brand New for Sale / Trade
for all I know it came out of a flooded basement. Or shall we say was never paid for...
So, going to buy new this time.
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
