Weak trailer brakes. Sure could use some ideas here!
   / Weak trailer brakes. Sure could use some ideas here! #31
Ya'll have me worried with warnings of series wired so I need to know how someone could make that mistake. I realize there are multiple ways of bringing + and - to each mag but in simple terms the + wire would go from 7 way to + wire on first mag,the - wire on first mag would run to + wire on secound mag,- wire on secound mag would run to + wire on third mag ect ,ect until - wire on last mag runs to - wire on 7 way. Is that how you are saying someone would wire brakes in series or is there other less obvious ways it might be wired in series? I ask because if it looks right to the one who did it,it might also look right to me. I suspect the fist voltage test would send up a flag but I'm asking for the guy doing a visual inspection for broke,disconnected or missing wires.
Yes, that would be a true serial connection, which can be done. In trailer brake world, there aren’t any real standards that everyone goes by. it’s always been a “that’s good enough” scenario.
There should be 2 wires running from the brake controller truck/trailer plug. A hot 12+ gauge (blue is often used) and a 12+ guage ground (white is usually used). One side of the magnet goes to blue, one side to white without grounding to the frame allowing for the best current path through the controller. Some deutsch type connectors would probably help but they cost about 4 bucks each.
People tend to ”ground out” the individual drums often using zip screws into the frame breaking the path. They tend to use clamp on splices or crimp on splices without heat shrink. Over time, corroding and contributing to an increase in line resistance. With current being reduced by resistance (current=voltage/resistance) the goal is to minimize resistance since voltage is the constant we need for the controller to do its job.
   / Weak trailer brakes. Sure could use some ideas here! #32
   / Weak trailer brakes. Sure could use some ideas here! #33
If you are really serious about having brakes, for crying out loud don't buy things with electric drums!! You can get electric over hydraulic discs for most axles and use an actuator that draws its power from a battery located near axles (blue wire then just become signal wire). Until 2 years ago, you could even get proper ABS, but Tuson sold their hydraulic side and new owner didn't want to be in the high liability brake business.
   / Weak trailer brakes. Sure could use some ideas here! #34
Thank you for the tip. I think I might have bought a clamp meter and checked this once before, but I'll do it again and post the findings. Thanks for the tip. I was thinking about trying to read the max potential amps at the trailer connector. Any idea how I could do this?
My MaxBrake controller shows the amperage draw for the whole system. Unfortunately, MaxBrake is no longer made and I don't know if other controllers have this feature. If you have an amp meter capable of more than ten amps, you could open your plug and put it in line for the brake circuit. Otherwise, I would put a meter in line with each brake magnet. This would require cutting the + wire. Low amperage could signal a couple of things, which can be found on Dexter's troubleshooting link. When splicing back together, I always solder and use adhesive shrink tube. I also like a dedicated ground wire run through the plug to the tow vehicle, using adhesive shrink tube on all connections. I don't like using the frame for a ground, but always run one from the frame to the ground wire to catch any lights that are grounded to the frame, but the brake wiring should not use the frame. On the tow vehicle, I like to run the ground wire from plug up the negative side of the battery. Others may differ on how they do things, but this is how I was taught 50+ years ago, and have towed livestock trailers and also equipment trailers in the oil patch all over Wyoming in some pretty demanding conditions. This is what has worked well for me.
   / Weak trailer brakes. Sure could use some ideas here! #35
When I bought my 15 y/o cattle trailer last year (double axle trailer with brakes on both), I bit the bullet and bought pre-assembled self-adjusting kits for each of the brakes that included the backing plate with all the hardware already installed. The brakes on the trailer looked like the originals and were covered in grease.
I also bought brand new drums for all sides.
Don't over grease. repeat - don't over grease. Don't use the bearing buddies on axles that have brakes. They tend to blow the grease out the back seal and then contaminate the drum/shoes and you are done. You can't clean grease off shoes. If you do use the bearing buddies, make sure you are spinning the tire as you are installing the grease.
Once I had them all adjusted, they were pretty good. They got better as they self-adjusted over the next few trips.
Also - in my experience, 80% of the time electrical issues on vehicles are ground related. Add more.
   / Weak trailer brakes. Sure could use some ideas here! #36
Bearing buddies are for boat trailers that get dunked. The pressure keeps the water out, but often blows out seals or greases brakes. I'm not sure if rotating while greasing helps. It pressurizes the outside of the bearing away from the seal.
Dexter EZ lube also has a grease zerk in a similar location. It has a hole in the axle going to the inner bearing. Pumping grease in puts pressure directly on that seal. Rotating the wheel while pumping in grease makes the grease flow through the bearing & avoid blowing out the seal. Under normal use there is no pressurized grease in this setup, unlike a bearing buddy.
Lots of people still manually pack EZ lube axles as it uses less grease, gives you a chance to inspect the bearing & most importantly won't blow out that seal.
   / Weak trailer brakes. Sure could use some ideas here! #37
Yep, I'm one of them.
Not to save on grease, but to get it to where it needs to be. That it allows me to check the spindles and bearings in the process is a very nice side effect.
In an ideal world, all my trailers would have oil bath axles.
   / Weak trailer brakes. Sure could use some ideas here! #38
Yep, that is series which you do not want... at least I don't think you do.
Now, the magnet wires I've seen are always the same for both sides, and +/- really doesn't matter.
How I've seen the trailers wired:
Black and white wires from the plug to the first axle. Split black 3 way, one wire to magnet at each end of the axle, and one wire to the next axle. Same with white, split 3 way, one to each magnet on first axle, and a wire to the second axle.
For the middle axle, the same, split the black 3 way, one to each end of the axle, and one to the next axle. White is the same.
Last axle just needs the black split 2 way one for each end. Same for white.
There would be a number of equivalent variations. You could cross the frame at the first axle, and then have parallel wires coming down each side of the frame which connects to the magnets. That may simplify it, and keep from running wires across the axles, but it will mean more drops from the frame to the axles.
With the axle brakes, you should also have a breakaway.
Hot wire to + on breakaway battery.
Ground to - on breakaway battery, and to the trailer/brake ground wire.
+ from battery to breakaway switch to your + strand for trailer brakes.
The breakaway switch may also help with testing your brakes. Yank the breakaway cable, then jack up each tire and see if it spins.
  • Good Post
Reactions: D&D
   / Weak trailer brakes. Sure could use some ideas here! #39
At this point is it safe to say (A) you know how wires are supposed to be routed (B) all contacts/connections are good (C) you have tested for consistant voltage drop at mags (D) truck has towed another trailer with similar set up to assure problem is with trailer ?
With those addressed and problem remaining something you said early on about switching drums still haunts me. Ideally new shoes are arc ground to fit drums at installation but unless drums are turned oversize arcing isn't usually required (even though it would help). It would be alot of labor pulling 6 wheels to confirm shoe/drum match but pulling 1 or 2 that aren't breaking might tell you something. Would 3 plasti-guage or putty, one on middle and each end tell us if shoe is makeing 100% or close to full contact? How about a chalk mark from end to end,reassemble,use brakes while towing,pull drum to see how much chalk is missing? Can a feeler gauge be inserted while helper applies breaks?
   / Weak trailer brakes. Sure could use some ideas here! #40
Haven't read all the many replies as I am getting into this late. My suggestions would be, if you haven't already solved this problem would be to make sure of your ground...all the way to the brake coil....as hooking up at the hitch may look good but not if corrosion gets in the way. Second, a problem I use to have with old ford drum brakes is make sure the shoe fits the curve of the drum, ie have it fitted.
Good Luck.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
SUV (A59231)
SUV (A59231)
