Weak trailer brakes. Sure could use some ideas here!
/ Weak trailer brakes. Sure could use some ideas here! #11
I believe all the bases have been covered but the bases are often evasive when it comes to trailer wiring. Since faulty ground accounts for most trailer light and brake problems let's solve that once and for all. Braze a 1/4" brass bolt head to trailer frame and connect ground from 7 way to it with brass washers and nut. If brake magnet grounds connect to backing plates ,extend wires to additional brass bolts brazed to frame. Reason for doing this is there are several BOLTED TOGEATHER components where high resistance can set up. Examine frame to make certain there is a continus path through WELDED joints going back to 7 way ground bolt. If lo and behold frame is bolted together, braze bolts on either sides of joint and jumper with copper wire or braze copper plumber strap across joint. While you have tools out, add bolts for light grounds. This pretty much takes ground failures out of the equation for life of trailer. Test brakes. If no joy go to work on hot wire connections starting at and including 7 way. There are no better cleaners and protectants than the Deoxit line of products. If brakes still don't work you have at least set the trailer up for reliable testing and long term dependabe wiring.
The alternate is to physically run a ground wire to every electric ground connection on the trailer and connect it through whatever means to the ground wire at the 7 pin connector and not even use the trailer frame as a ground. Works great with LED lights that have a separate ground wire unlike incandescent lights that ground through a mounting bolt in the light housing. But even those would benefit with a direct ground wire connection as you mentioned.
Check to see what the amperage draw is on each magnet. It should be 2.5 - 3 amps at full actuation, depending on brake size. Just because you have voltage, it does not mean there is enough amperage for the brakes to properly work (bad connections, insufficient wire size, poor grounds, etc.). Here is a link to Dexter's troubleshooting page.
Home | Dexter Axle Co
Thank you for the tip. I think I might have bought a clamp meter and checked this once before, but I'll do it again and post the findings. Thanks for the tip. I was thinking about trying to read the max potential amps at the trailer connector. Any idea how I could do this?
I'd suspect the connector/ground or the controller. Is the controller built into the truck (OEM) and/or adjustable?
Yes, it's built into the truck.
I ran a dedicated ground and not a chassis ground. There is a chassis ground at the junction box.
There's no practical way to clean grease off of brake shoes or pads. Definitely not with with rags anyway.
Once oily or greasy they're junk. Drums and rotors are easily degreased with brake cleaner, though.
Either way, not relying on Bearing Buddys for getting grease to the bearings is a good idea.
If I could purchase shoes separately, I would have replaced them. Unfortunately, the shoes are only available with the backing plates and they cost $150 per axle. Times 3 axles.
/ Weak trailer brakes. Sure could use some ideas here! #16
There are only 2 ways to read current on something like this. A DC clamp on or get a DMM in series with the circuit. If it's more than 10 amps most meters cant handle the series measurement.
/ Weak trailer brakes. Sure could use some ideas here! #18
Looks like NAPA, for example, sells brake shoes separately.
/ Weak trailer brakes. Sure could use some ideas here! #19
I have included a wire ampacity chart directly from UL 508A. Check the insulation and wire type on the jacket of your wire. Make sure you are using copper wire, not aluminum or copper clad aluminum. Find out the Full Load Amps of one of your brake actuators and multiply that number by the number of actuators you have. That will be your full load amps on your braking circuit. Check the insulation temp rating on your wire/cable. Most should be at least 75 Degrees C. The higher, the better. Using the chart supplied below, go into the 75 Degrees C column under Copper, and try to match your full load amp draw when all brake actuators are activated in the AWG column. I always choose my wire size by bumping the full load by 125%. That is the biggest wire size you will ever need. Anything larger is just a waste of money. Running the short distance of the trailer bed to the axles is not a long enough distance to get a voltage drop from wire resistance, provided you use the proper gauge wire for your load.
As other posters have said, make sure your brake actuator wiring circuit is wired parallel, not in series. Do ensure you have an excellent ground for every actuator, and an excellent ground for the ground pin on the seven pin plug, both on the trailer and the truck. Do not rely on the ball on the hitch to make the ground connection from your trailer to your truck. That may sound funny, but I have seen many trailer electrical issues through the years where people were relying knowingly, or unknowingly, on the hitch ball connection for the ground circuit and then couldn't figure out why nothing work properly 100% of the time.
/ Weak trailer brakes. Sure could use some ideas here! #20
All of the trailers I've seen run two wires from the front of the trailer to the brakes without grounding through the chassis. Lights are often grounded to the frame. On my little red Haulin trailer, I welded the light brackets to the trailer frame to improve the ground.
As far as the brakes, usually 2 wires from the front to the axles, then branching out to all the individual brakes. Effectively in parallel.
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2024 JOHN DEERE 85G EXCAVATOR (A59823)
2024 JOHN DEERE...
John Deere Hopper Assembly Kit (A60463)
John Deere Hopper...
(INOP) 2009 FORD CROWN VICTORIA (A59823)
(INOP) 2009 FORD...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
