Grapple W.R. Long Grapple
/ W.R. Long Grapple
Placed an order today for a RBG2-60" grapple so eventually I will get you some photos and give a review.
/ W.R. Long Grapple #22
Did you get a valve kit too? I've grown to like my WRLong diverter valve. It took a while to get used to it after being familiar with the rear remote set up but I am now pretty comfortable with the diverter and like it.
/ W.R. Long Grapple
No valve kit, for now I'm just going to use the remotes but at some point I will get one.
/ W.R. Long Grapple #24
You'll do fine with the remotes. I used that for two years and had a hard time adjusting to the diverter valve once I got a new tractor. As with any new control (diverter or remote), it will take 4-5 hours of use before things become natural to you but it will happen.
/ W.R. Long Grapple #25
Island -
Not trying to hijack the thread but I'm curious if after using both the remotes, and now the diverter, is the diverter worth the addl. $500 or so?
I'm using my rear remotes, and while not quite as convenient, are functional. Also, I'm curious as to what made you decide to purchase the diverter?
/ W.R. Long Grapple #26
I used a rear remote to control the grapple on my CK20 for two years and was perfectly happy with that arrangement. I got a WRLong diverter essentially for free as part of a purchase of a used 4n1 bucket for my new DK40se so I decided to have the diverter installed. It took some getting used to and I am still (40hrs later) still not quite as comfortable with it as I was with the separate remote lever but I don't have any complaints. If I were to do it over I would mostly consider where the remote lever would be and whether it was in a natural place so that you could drop your hand from the FEL controller to the remote without looking. If you needed to reach around something or if the motion was not one that quickly became "unconscious" (like driving a stick shift car) then I'd say the diverter would be better.
The only downside of the diverter for me at least is that you need to be careful in timing the pressing and release of the button so you don't get combined movement of open/close with dump/curl. For example, if you still have the FEL lever pushed into the close/curl position with your finger on the button to divert to grapple close and then you release your finger before allowing the FEL control lever to return to neutral position, the grapple will curl unexpectedly. That is never an issue with rear remotes as your hand is off the FEL controller and therefore it is in neutral position automatically. It may seem dopey to have that problem but when you are working fast it is remarkably easy to inadvertently curl or dump the grapple. Not really a big deal but it is for me a downside of the diverter set up compared to the rear remote. Electric over hydraulic set ups would avoid that but I have a standard diverter set up.
It would not have been difficult to use the rear remotes on my new tractor. On my DK I have two sets of rear remotes. One, the standard remote, has a controller with indents and the other optional one is just spring loaded with no indents. I'd clearly use the one without indents so I didn't inadvertently lock the grapple in open or closed position. The remote with indents is really intended for a BH or log splitter where you would put it in the "on" position and leave it there. For controlling a grapple it is better to have a remote control lever that is just spring loaded so it returns automatically to neutral (off) position as soon as you release it.
Bottom line for me is that I would prefer to spend $500-600 on an extra implement and just use the rear remote to control a grapple so long as the ergonomics of the remote and FEL controller are convenient. I am happy with the WR Long diverter valve but it is not really such an advantage over using a well designed rear remote set up.
/ W.R. Long Grapple #27
Island, Do you think a true 3rd function valve would be easier?
/ W.R. Long Grapple #28
It would overcome the issue I described of having inadvertent loader movements when you let go of the diverter button too soon. A true third function valve (what I believe is also referred to as electric over hydraulic by WRLong) would be nice but is even more expensive than the diverter set up. I'm not certain but I think you end up pretty close to $800+ by the time you get one of those installed.
Bottom line for me is that if you have a rear remote you might as well use it to see if you are satisfied. If you don't have a rear remote and don't see any other reason to add one, then either the diverter or electric over hydraulic solutions are more money but work well. If money is no object then electric over hydraulic is best.
/ W.R. Long Grapple #29
The electrohydraulic valve by WR Long is great. Don't recall price though, since was included in package of other dealer work.
/ W.R. Long Grapple #30
i think what shaley really meant was a true extra valve by the joystick for the fel.i have mine set up with 3 extra valves.i think it was easier and less expensive than devierter valve
/ W.R. Long Grapple #31
Easier maybe, less expensive surely but cute....not really!:eek: :D Did you never have a standard FEL controller or did you just replace it?
/ W.R. Long Grapple #32
island,the fel valve is still there.this valve hooks to the pb circuit and i did clean up the hose run's after i made sure everything work right;)
/ W.R. Long Grapple #33
If you still have the standard FEL controller, why are there two additional valves? I'd think you would only need one for open/close grapple.
/ W.R. Long Grapple #35
Gotcha. So you don't have rear remotes and you use the "dash" mounted remotes for both rear and front. Very clever.
/ W.R. Long Grapple #36
i have 1 rear remote so i could have a t or t but not t n t:D and the price of a 3 valve is very close to a 1 so on it went .if you wanted to go crazy you could put as many as can fit :rolleyes:
/ W.R. Long Grapple
Well I picked up my RBG2-60 grapple today; have it sitting on my trailer waiting for my trip to the farm this next weekend. Only problem is I'm going up for the last weekend of hunting season so I probably won't get it installed on this trip and since it's Christmas time I probably won't be heading back up until New Years. Oh well my projects will still be there next year!
/ W.R. Long Grapple #38
Man, are you going to be able to survive looking at that grapple in your driveway every day for a month and not be able to use it??? Play hooky. Get that puppy installed and send us some pics.:D
/ W.R. Long Grapple #39
We've been selling the the RBG72's for the 35/40/45 Case IH & New Holland Tractors. It's a light enough attachment that it doesn't eat up all your lift capacity. Good Luck!
/ W.R. Long Grapple #40
While you are certainly right that it "doesn't eat up all your lift capacity" it certainly would eat up a very large portion of it. Looking at the 250TL loader for the 40/45hp NHs that have about 2000lbs lift capacity then adding a 665lb grapple is eating up a full third of that lift capacity and leaves you with only 1345lbs to work with. Compare that to adding a 280lb grapple which would leave 1720lbs. That is a pretty big difference, almost 400lbs of extra lift capacity. It wouldn't interfer with moving brush but it could certainly limit your ability to move rocks and trees.
WR Long's recommendation, that a loader with only 1300lbs lift capacity such as on a 35hp tractor should be fitted with a RGB60 grapple weighing 567lbs is nuts. That would leave you will only 633lbs of lift capacity or about what a Kubota BX SCUT could lift. That is hopeless if you are moving logs or rocks. I have a 48" 280lb grapple on a loader rated to lift 2700lbs and it has worked just fine. I can still lift more than a ton with that set up. Costs about half or less than the WRLong RGB too. I love the WRLong design but putting the heavier RGB versions on CUTs just does not make sense. The 48" or 60" RGB2 at 325/365lbs or the Millonzi at 280lbs makes a whole lot more sense for the vast majority of CUT owners who have loaders that lift less than 2500lbs.
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
