Forks Using one fork as a boom?
/ Using one fork as a boom? #1
hz293
Kalama,WA
Kubota B7510HSD
I've seen info about making a boom pole for the FEL and the 3ph on this site. I haven't seen anything that addressed using a portable fork for one. I've got a Kubota 7510hst that I made 3 1/2 foot portable forks for out of 4" channel. Is there any reason that one of the forks can't be used as a boom pole if I only pick up 300lbs or so maximum? The loader is rated for 770lbs.
Harris
/ Using one fork as a boom? #2
I'd be worried about hanging all the weight off one side of the loader maybe tweaking the frame; may be a non-issue though depending on how strongly it's built and how much weight you put on it.
/ Using one fork as a boom? #3
I use one fork centered in the middle of the bucket. Works well for limited weight. Depending on the geometry, 300 pounds could easily max out your loader.
/ Using one fork as a boom? #4
I have turned one fork upside down on the frame, centered it, and pulled out engines with no problem. I think you will be fine.
/ Using one fork as a boom? #5
I used both forks. This isn't a fork adapter that hangs off the bucket, this is a quick detach fork capable of about 2k. I welded two pieces of 3 1/2 foot long rectangular tubing together. Then I laid them centered over an I-beam and welded them up each side. I have not tested how much weight it will lift, but it isn't coming off. I slide both forks together and just drive into the rectangular tubing. My goal was to be able to set trusses so I do not need much lift capacity. I know the weight of the I-beam is heavy which reduces how much I can lift, but it was a free I beam given to me by a friend so I used it. It was 14 feet long so on the New Holland 45 with I-beam mounted on the forks I can lift 23 ½ feet tall. I have a 758c backhoe mounted on my TC-45 which probably gives a good amount of counter balance.
I have seen somewhere on here a couple of good ideas like you are suggesting. One guy posted pictures on here about using a basement jack slid onto a single fork for setting trusses. He used one fork, and it was a round basement jack so it just slid over the top of the fork. If it were small loads it would probably be OK. I would be concerned about bending something if both lift arms were not used together on a heavy load, which is why I build mine like I did. I wonder if you could piggy back off the other guys idea and use 2 basement jacks welded or chained together for equal pressure on each lift arm but a light pole which allows more weight capacity and less counterbalance needed. Paul
/ Using one fork as a boom? #7
I bolted a 12' 4x4 to the middle of my forks, am lifting trusses up to 17'. THey weight 144#
/ Using one fork as a boom? #8
I took my first pictures of the tractor now that I have a digital camera. Here is the small I beam I welded on the rectangular tubing that was pre-welded together. Paul
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
King Kutter 5' 3Pt Tiller (A66285)
King Kutter 5' 3Pt...
2015 Ford F-150 Pickup Truck (A62613)
2015 Ford F-150...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
