Forks Using one fork as a boom?
/ Using one fork as a boom? #1
hz293
Kalama,WA
Kubota B7510HSD
I've seen info about making a boom pole for the FEL and the 3ph on this site. I haven't seen anything that addressed using a portable fork for one. I've got a Kubota 7510hst that I made 3 1/2 foot portable forks for out of 4" channel. Is there any reason that one of the forks can't be used as a boom pole if I only pick up 300lbs or so maximum? The loader is rated for 770lbs.
Harris
/ Using one fork as a boom? #2
I'd be worried about hanging all the weight off one side of the loader maybe tweaking the frame; may be a non-issue though depending on how strongly it's built and how much weight you put on it.
/ Using one fork as a boom? #3
I use one fork centered in the middle of the bucket. Works well for limited weight. Depending on the geometry, 300 pounds could easily max out your loader.
/ Using one fork as a boom? #4
I have turned one fork upside down on the frame, centered it, and pulled out engines with no problem. I think you will be fine.
/ Using one fork as a boom? #5
I used both forks. This isn't a fork adapter that hangs off the bucket, this is a quick detach fork capable of about 2k. I welded two pieces of 3 1/2 foot long rectangular tubing together. Then I laid them centered over an I-beam and welded them up each side. I have not tested how much weight it will lift, but it isn't coming off. I slide both forks together and just drive into the rectangular tubing. My goal was to be able to set trusses so I do not need much lift capacity. I know the weight of the I-beam is heavy which reduces how much I can lift, but it was a free I beam given to me by a friend so I used it. It was 14 feet long so on the New Holland 45 with I-beam mounted on the forks I can lift 23 ½ feet tall. I have a 758c backhoe mounted on my TC-45 which probably gives a good amount of counter balance.
I have seen somewhere on here a couple of good ideas like you are suggesting. One guy posted pictures on here about using a basement jack slid onto a single fork for setting trusses. He used one fork, and it was a round basement jack so it just slid over the top of the fork. If it were small loads it would probably be OK. I would be concerned about bending something if both lift arms were not used together on a heavy load, which is why I build mine like I did. I wonder if you could piggy back off the other guys idea and use 2 basement jacks welded or chained together for equal pressure on each lift arm but a light pole which allows more weight capacity and less counterbalance needed. Paul
/ Using one fork as a boom? #7
I bolted a 12' 4x4 to the middle of my forks, am lifting trusses up to 17'. THey weight 144#
/ Using one fork as a boom? #8
I took my first pictures of the tractor now that I have a digital camera. Here is the small I beam I welded on the rectangular tubing that was pre-welded together. Paul
2016 Dodge Ram 5500 (A64127)
2016 Dodge Ram...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
Front Tank Bracket (A64127)
Front Tank Bracket...
King Kutter II Tiller for sale.
King Kutter II...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
