Buying Advice Used JD 110 vs everything else
/ Used JD 110 vs everything else #41
I know that the OP has almost decided to go with a 110, but my thinking is that for 30-35K, one can get a lot of tractor new, even with a BH. As he seems to have a property that will need constant work, a tractor wouldn't be a bad idea. I would be inclined to get a new tractor with BH, then he has it, and the 110 can't be used for general upkeep. The 110 might do the initial jobs a little better, but over the long run a tractor would probably come out ahead. As the OP isn't interested in HST, there are plenty of basic options for heavy solid tractors that will do his initial jobs and upkeep work down the road. At this point, used isn't cheaper than new, so why go used?
/ Used JD 110 vs everything else #42
The 110tlb is a tractor. The BH can be removed and it even has a PTO/3pt option.
/ Used JD 110 vs everything else #43
I do like the creep function when using the backhoe... it's the cat's meow.
/ Used JD 110 vs everything else #44
The loader on a SCUT, CUT or a utility farm tractor is designed to load material, scoop up piles, etc. It really is not designed to dig, at least not at any decent duty cycle. If you look at a Bobcat skid steer, you will see when the loader is all the way down (digging position), the lower arms are actually against the body of the Bobcat. If you look at a JD210 and observe the angles and the way the hydraulic rams attach, you can also see how it can dig all day long. On the JD110, it's pretty stout, but I've seen enough busted bell housings to think most of the digging should be done with the backhoe, with the loader relegated to loading and relatively light digging work. I've never seen anyone bust a bell housing, I've just seen the results. It makes me wonder if they were truly abusing the unit or if more likely the bolts worked loose over time allowing dynamic loads on the bolts. I guess I am saying that a good operator that maintains his JD110 well and isn't stupid may be able to do more digging with the front bucket than I suspect.
DavesTractor,
I have heard of the horror stories of the 110tlb with the busted / cracked bell housings. Are you saying that this can be avoided by not using the 110 like a bulldozer? Thanks in advance for the info
/ Used JD 110 vs everything else #45
You know... I've heard those concerns before. Maybe I've just been lucky - cause I've dug alot of stumps, roots and frozen ground with my 110.
But, I also try to "pay attention" when I'm working.
And, I've always maintained that there's not any tractor, excavator, dozer, etc., etc. that can't be "broken"!
AKfish
/ Used JD 110 vs everything else #46
DavesTractor,
A little care in operating the machine, not making big impact type loads on the castings and you'll never break a JD110. They are a solid tractor. Like AKfish mentions, he has done a ton of work with his without issue. I do not think the JD110 is particularly weak in the bell housing, I just think it runs a really stout loader and if used like a "rental" you can break it. I would not let that affect a decision to buy one of these. If it isn't already cracked or broken, it is highly unlikely a careful operator will break it. If I didn't already have a skid steer and mini-excavator at home, I'd consider a JD110. I wish Mahindra made a dedicated TLB for the USA market. We sell a ton of backhoes on the smaller Mahindras and folks are happy with these just like the green JD and the Blue NH (as opposed to commercial units). But they are a small farm tractor with a backhoe attachment, not a dedicated machine. You give up some reach and strength for the versatility of being able to quickly dismount the backhoe and attach implements.
I think JCB makes a "midi" 50'ish HP TLB. I've not owned or used one, but that sounds like a good size.
/ Used JD 110 vs everything else #47
DavesTractor,
I'm not sure exactly what people were doing or what it takes to crack the bell housing. Likely a combinations of factors - not just one, single thing.
Something that I'll admit to doing and fully realize that I should "NEVER" do is work the backhoe with the stabilizers and bucket UP. Yeah, it really twists and torques the tractor. Usually, it's just a little, quick scoop or grab of a stump or tree.
But, it's just a sec or two and don't want to take the time (or space) to get the tractor all set up. Lazy.. I know. I finally learned my lesson after swinging the hoe boom smack dab into one of the stabilizer feet!!
So, there's alot of ways you can subject the machine to stresses that are outside of the design criteria. Stupid bulldozing piles at high speed or working the backhoe without 4-point stabilization...
AKfish
/ Used JD 110 vs everything else #48
Yes, I get that. It is still not quite the same though. If the OP is comfortable with it, fine, but it just seems that that is a lot of money to spend on a used machine that is not as adaptable as a modern utility tractor.
/ Used JD 110 vs everything else #49
Yeah but he has like 4 or 4.5 acres I believe. Once everything is built the backhoe becomes an expensive yard ornament. Buy a used heavy machine and flip it into a tractor later.
/ Used JD 110 vs everything else #50
Good point, and I agree, he really doesn't need a backhoe in the long run. But if he buys a used machine, uses it for 2-3 years, is he going to get a decent price for it at that point, so as to be able to buy a good utility tractor. It won't have to be as big, but 30K is a lot of money. Most likely you guys are right, but I would still consider going new. Then again, it's his money!
/ Used JD 110 vs everything else #51
If he'd give me a blank check I'd hook him up with a mini ex, compact track loader, d6 dozer and a dump truck.
/ Used JD 110 vs everything else #52
Don't forget all the attachments to do everything perfectly!!!!!
You guys are awesome! I guess the other detail is that I don't have a Commercial Driver license, and don't plan to get one either. It's gotta be the one machine, so it looks like you helped me convince myself I need a 110.
Am I the only one who's concerned about all the emissions crap on the new tractors? Maybe I'll wind up keeping the 110 if I can find one.....
/ Used JD 110 vs everything else #54
Well, you may be able to buy mine from my estate -- unless I convince my grandson it is too useful to part with.
/ Used JD 110 vs everything else #55
I don't have any experience with Tier 4, but when I bought my Tier 3 CK, every dealer, regardless of brand, told me to buy before Tier 4 took over. From what I know I wouldn't want one. I will say that I have a 1950s Farmall H, that still works great, and I would bet that its 30HP would outpull many modern higher horsepower tractors, so I believe that sometimes the older iron can just keep on working.
/ Used JD 110 vs everything else #56
Those of you with experience with the 110, how capable is the backhoe in regards to small excavation work like digging out stumps and general lot clearing / site prep?
I'm not talking about clearing 10 acres, but I do work for some developers clearing residential lots, up to an acre usually.
Thanks in advance.
/ Used JD 110 vs everything else #57
Thanks in advance.
That's it's intended market
/ Used JD 110 vs everything else #58
Without ballast in the tires, I show a JD110 TLB at 7280 lbs. That would work with the correct trailer and keep you just under the CDL requirement in CA. You just can't pull a trailer rated at over 10k lbs. With ballast and the 4-n-1 you would be too heavy for a 10k lb trailer.
As far as using the backhoe and then some day it becoming a yard ornament....that's never happened to me. We have 10 acres, most of it all finished up and I still use my mini-ex regularly. I suppose if you had a 100% landscaped property you might run out of a use for it.
/ Used JD 110 vs everything else #59
You're all wrong about trailer weight and CDL's.
My experience with the 110 was putting in a leech field in tough clay and it was a breeze with a 24" bucket. The creep-to-reposition made moving along the trench super easy, and when the septic was signed off, I rebuilt the motocross track with the 4 in one loader. The backhoe worked great for shaping the berms on the corners with the sideswing of the bucket. I also used it to dig around some large redwood stumps, but it wwasnt strong enough to break them loose on its own. In all fairness to the 110, the stumps were about 24" across at the trunk, and the root ball was about 6 feet in diameter. I wound up getting it out with a big-rig tow truck and its 50k lb winch.
I probably sound like a JD salesman, but i came here to find a cheaper alternative. So far, it seems like it has no real equal.
Caterpillar 330/330L Excavator Parts and Service Manuals (A63117)
Caterpillar...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2001 John Deere 6210 (A60462)
2001 John Deere...
LOOK! (A63111)
LOOK! (A63111)
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
