Uplifing experience
/ Uplifing experience #1
Red Zebra
Fox Meadow TN
'07 PT 425
Lifting with a PT.........
I seem to recall seeing a custom "man-lift" somebody built for a 425...anybody make one? Pictures? I need to be able to quickly and safely access some parts of my barn and house without dragging ladders around.
I built 2 cutom sized pallets for my 425 to hold nine-80lb bags of quick-crete (or other stuff). The rough dimensiens are 36" wide and 30" deep. Keeps the bulk of the material close to the arms. I used some scrap treated lumber so I can leave them outside.
And a pic of my home-made lift boom taking Rusty out of the barn--he's about 350lbs. And another of Rusty roaming the front pasture. (Iknow, I need a hobby.)
/ Uplifing experience #2
Looks like you've got one - skeerin' the neighbors!
/ Uplifing experience #3
/ Uplifing experience #4
My concern would be the rate of leak down from the cylinders, and the possibility of someone/something hitting the controls and dropping me in a hurry.
-Rob :)
/ Uplifing experience #5
We do a poor mans job of what you have (A pallet, and a rope tied to the fork lift).
My problem is what Rob said, friggin leakdown of the control valve. You get up there, and in minutes the pallet has gone down. Cheap valve systems on the PT but I don't have a clue what could be easily swapped out and in for this control. The guys have suggested simple lock offs and it is probably the best way to go...
/ Uplifing experience #6
There is no leak down with the machine running. However, you bring up a very valid point about someone or something hitting the joystick when you are up there. A simple hinged C bracket to flip over the joystick shaft would prevent this from happening.
/ Uplifing experience #7
The hard part is getting up and down from the platform. As I recall, Pajoube injured his knee getting off or on that very platform.
/ Uplifing experience #8
I get leakdown with my engine running. I thought was just how it was. You are saying that if the engine is running you shouldn't have any leakdown?
/ Uplifing experience #9
AFAIK, there is no leakage compensation when the valve is in the neutral position regardless of whether the engine is running or not.
I've used a pallet on forks as a low-level scaffold a few times. It always drops and tilts after a while. I've got hopes of figuring out a way to brace a platform back to the frame of the PT so that the hydraulics are only used to move the platform into position.
/ Uplifing experience #10
I've used a similar knock up for trimming trees up high. After the pallet / platform was set and level we used a ladder to get up to level. At no time would it be safe to "ride" the platform up
With a 9' lift a 20' ladder will reach everywhere it is needed.
Rgds, tim
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
TRACTOR SHEDDER (A60736)
TRACTOR SHEDDER...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
Komatsu WA270 (A60462)
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
