Tree shear
/ Tree shear
So ...... how much was it? With your link you can’t see price unless you create an account.
List price was $4,720 built with American made steel in Minnesota. I worked with Aaron Stubbs who was great to work with just can't wait to put it to use.
/ Tree shear #42
I worked with a friend of mine with his tree shear , it was awesome , But he mounted it on his mini ex . It was cutting up to 12 inch trees . Had a skid steer there with a brush cutter and my tractor with forks to move the logs . We cleaned up a 2 acre plot full of dead wood , vines and trees in a day and a half . Never fired up a chainsaw
/ Tree shear
That is my goal keep the chain saw work to a minimum.
/ Tree shear
Well came in less time than quoted now to get it home and work it. IMG_20171221_143221085_HDR.jpg
/ Tree shear #46
We're going to need some video proof sir.
/ Tree shear
Will do on the video I have to get down to the farm next week as not much to cut at my office in town, but saved on the freight dropping at a business with a forklift.
/ Tree shear #48
Out of curiosity, why choose a tree shear over a tree puller or a stump bucket +/- grapple? The tree shears seem to run more than double what either of the other two implements run, and the shear leaves behind a stump and roots...
/ Tree shear #49
Locally a tree puller can be purchased for $1250.
Problem comes with a tractor too small to use it to it's capacity. A shear somewhat overcomes that.
A shear definitely has it's place. Just have to accept the aftermath.
/ Tree shear
I have a backhoe and grapple, but need to take down a bunch of cottonwood and other invasive trees out of trees we planted 20 years ago. Pictures to follow, hopefully this is right tool for the job.
/ Tree shear #51
Looks like problem was solved many years ago?
/ Tree shear #52
Today's Safety Police would find soooooo many things wrong with that...... ;)
/ Tree shear
But I would love to have that to take to the shows. And I found several that were very similar that mount on bobcats
/ Tree shear #54
I chose a tree shear about 10 years ago, because my MF240D didn't have a loader and we were overrun with cedar trees:
I put the loader on the TORO so I could pick them up with a homemade brush fork and make burn piles:
/ Tree shear #55
Eastern Red Cedars are out of control here too. That has happened in the last 50 years. As a kid we had to search to find one suitable for a Christmas tree. Today they are everywhere. I'm not a fan of them. They will eventually crowd out our large hardwood timbers. :(
/ Tree shear #56
I would think that an effective tree puller on a CUT would require a second hydraulic cylinder pushing against the ground, since the lift capacity of most CUTs isn't great enough to pull many trees in the 4-6" range (especially hardwoods).
/ Tree shear #57
Although rare, I've saw pullers designed like that.
Your comments are why I mentioned earlier that a puller requires a larger tractor than a shear.
/ Tree shear #58
1195 (A64280)
1195 (A64280)
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
2022 EZ-GO ELITE...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Alliance Rear 16.9/14-38 Clamp On Rims (A64119)
Alliance Rear...
