Tree shear
/ Tree shear
So ...... how much was it? With your link you can’t see price unless you create an account.
List price was $4,720 built with American made steel in Minnesota. I worked with Aaron Stubbs who was great to work with just can't wait to put it to use.
/ Tree shear #42
I worked with a friend of mine with his tree shear , it was awesome , But he mounted it on his mini ex . It was cutting up to 12 inch trees . Had a skid steer there with a brush cutter and my tractor with forks to move the logs . We cleaned up a 2 acre plot full of dead wood , vines and trees in a day and a half . Never fired up a chainsaw
/ Tree shear
That is my goal keep the chain saw work to a minimum.
/ Tree shear
Well came in less time than quoted now to get it home and work it. IMG_20171221_143221085_HDR.jpg
/ Tree shear #46
We're going to need some video proof sir.
/ Tree shear
Will do on the video I have to get down to the farm next week as not much to cut at my office in town, but saved on the freight dropping at a business with a forklift.
/ Tree shear #48
Out of curiosity, why choose a tree shear over a tree puller or a stump bucket +/- grapple? The tree shears seem to run more than double what either of the other two implements run, and the shear leaves behind a stump and roots...
/ Tree shear #49
Locally a tree puller can be purchased for $1250.
Problem comes with a tractor too small to use it to it's capacity. A shear somewhat overcomes that.
A shear definitely has it's place. Just have to accept the aftermath.
/ Tree shear
I have a backhoe and grapple, but need to take down a bunch of cottonwood and other invasive trees out of trees we planted 20 years ago. Pictures to follow, hopefully this is right tool for the job.
/ Tree shear #51
Looks like problem was solved many years ago?
/ Tree shear #52
Today's Safety Police would find soooooo many things wrong with that...... ;)
/ Tree shear
But I would love to have that to take to the shows. And I found several that were very similar that mount on bobcats
/ Tree shear #54
I chose a tree shear about 10 years ago, because my MF240D didn't have a loader and we were overrun with cedar trees:
I put the loader on the TORO so I could pick them up with a homemade brush fork and make burn piles:
/ Tree shear #55
Eastern Red Cedars are out of control here too. That has happened in the last 50 years. As a kid we had to search to find one suitable for a Christmas tree. Today they are everywhere. I'm not a fan of them. They will eventually crowd out our large hardwood timbers. :(
/ Tree shear #56
I would think that an effective tree puller on a CUT would require a second hydraulic cylinder pushing against the ground, since the lift capacity of most CUTs isn't great enough to pull many trees in the 4-6" range (especially hardwoods).
/ Tree shear #57
Although rare, I've saw pullers designed like that.
Your comments are why I mentioned earlier that a puller requires a larger tractor than a shear.
/ Tree shear #58
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61572)
Pallet of...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
POWDER RIVER XL SQUEEZE CHUTE (A63291)
POWDER RIVER XL...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
